Just stripped all the sound material out of my LS
Old Dec 3, 2001 | 08:48 AM
millertime's Avatar
New User
Default Just stripped all the sound material out of my LS
I just got done stripping the sound deading material out of my LS. It took only about 1 hour with 2 guys. It was cold out so it made the **** brittle and it broke right out. I weighed it all, about 15 lbs, o well not very much buy it was free, and the sound aint that much different unless you are doing 80 on the highway. Other than that I just crank up the stereo. Just thought Id share.
Old Dec 3, 2001 | 09:48 AM
Disco Monkey's Avatar
Default Re: Just stripped all the sound material out of my LS (millertime)
how did you brake it? just chisel (sp?) it? and how cold was it? i am looking to do this to my gsr...
also i like your signature...very funny.
Old Dec 3, 2001 | 10:02 AM
b18b98's Avatar
Default Re: Just stripped all the sound material out of my LS (Disco Monkey)
Yeah..give us more details...i'm looking to do the same..
Old Dec 3, 2001 | 10:08 AM
InfamousRS's Avatar
Default Re: Just stripped all the sound material out of my LS (b18b98)
I don't think its worth it. Its only 15 lbs! Maybe if it was like 100 lbs it would be. Im thinking of adding sound deadening to my Teg, I hate road noise.
Old Dec 3, 2001 | 10:52 AM
B2FiNiTY's Avatar
Default Re: Just stripped all the sound material out of my LS (BLK94RS)
Hahah. You would hate driving an ITR then.
Old Dec 3, 2001 | 10:54 AM
HX_Guy's Avatar
Default Re: Just stripped all the sound material out of my LS (B2FiNiTY)
Which areas did you remove tar from? The trubk, back stea, front seats and firewall?
Old Dec 3, 2001 | 11:14 AM
four27's Avatar
Hey guys, you can use an air chisel set on low and I got my sound deadening out in my heated garage in 45 minutes. As soon as the vibration hits it it chips right out and if yu are careful you can do minimal scratching of the floor. Wipe up the remaining glue left behind with laquor thinner and you are done.
Old Dec 3, 2001 | 12:39 PM
JL 74's Avatar
Me too. I really hate the road noise especially on a long drive. My wife hates riding in my GSR.
Old Dec 3, 2001 | 01:19 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Just stripped all the sound material out of my LS (jl74)
I gotta chime in on this too.
When I bought my Civic, I was a audio freak. Loved sound, so I piled about 40lbs of sound deading material in my car, and eliminated all rattles and creaks.
Let's just say that at 100mph, my car is quieter than my buddy's at 65. And we have the exact same car, motor, tires and exhaust.
I love it, and would never remove 15lbs of material for my sanity.
Plus you can talk to your chick while driving and you don't have to yell at her!
Old Dec 3, 2001 | 02:12 PM
InfamousRS's Avatar
Default Re: Just stripped all the sound material out of my LS (B18C-EJ1)
What kind of material did you use? CAE, Dyamat or what?
Old Dec 3, 2001 | 02:49 PM
fangtl's Avatar
Sound deadening material is really easy to remove believe it or not. If you live in a rather chilly environment, leave you car with the carpet out and the door opened for ~ a few hours at night (below freezing is best), and let the material harden, then all you have to do it use a little pressure (hammer, chisel, whatever) and it just breaks off.
Granted, you must have a secure environment. Don't want to have the car stolen because of you're trying to lose a few pounds. Also, dry ice works well.
Old Dec 3, 2001 | 03:03 PM
B18C-EJ1
Guest
Posts: n/a
Accumat by scoche. It's not asphalt based, it's rubber. Double side sticky tape instead of heating it up like dynamat.
I did every panel in the car including the trunk. Not just strips, but full sheets of the stuff.
So quiet..............
Old Dec 3, 2001 | 03:47 PM
nugget8000's Avatar
New User
OT-B18c-EJ1-where did you pick that stuff up from? Also, did you lay it down on the metal panels or on the back of the plastic panels? Thanks in advance for any info
Old Dec 3, 2001 | 04:26 PM
Rhetoric's Avatar
Default Re: Just stripped all the sound material out of my LS (nugget8000)
I stripped out ALL of my tar in my car and it was not 15lbs. It took me almost 3 days of sweat and blood labor. Not to mention getting it all out of the front part of the car you have to duck your head up in there and have a minimum amount of space to hit the tar at an angle. My guess is about 35lbs, that bag was pretty damn heavy. I thought I did a pretty clean job, looks like it was never there in the first place, I'll post a pic of my interior later on.
Old Dec 3, 2001 | 04:40 PM
kikkoboyie's Avatar
New User
Default Re: Just stripped all the sound material out of my LS (G S R)
yea post post post
Old Dec 3, 2001 | 05:37 PM
Integra187's Avatar
just curious where is the sound deading stuff in the car?
Old Dec 3, 2001 | 07:03 PM
Rhetoric's Avatar
Default Re: Just stripped all the sound material out of my LS (redteggy)
hey gsr guy im a weight freak dude and im trying to pull that sound deadening stuff out could u tell me exactly where its all located at thanks alot
In the back, it is underneath where the spare tire is at. Left, right and above the spare tire location. Also it is underneath the rear seats. The tar in the complete rear may weigh around 15lbs-20. Now for the front. You have to take out your front seats, and the interior carpet (I think you have to take out the rear quarters in order to take out the interior rug since the quarters over lap it by the door jams. The tar in the front is under your seats, also under the floor mats and reaches under the pedal assembly. It also overlaps the underneath the dash from driver-passenger. The rear is the easiest, you can get away with it in an hours work. The front is a pain and if youre in there chiseling long enough youre back will ache.
[Modified by G S R, 4:04 AM 12/4/2001]
Old Dec 3, 2001 | 07:05 PM
millertime's Avatar
New User
I havent taken the stuff by the firewall off yet, I dont know if i will, I have 15 lbs so far, I guess there is like 10 lbs more by the firewall
Old Dec 3, 2001 | 07:09 PM
InfamousRS's Avatar
Im guessing removing the sound deadening on the fire wall would make the bigest diference noise wise inside the car. Our enginse are extremley loud at higher rpm's.
Old Dec 3, 2001 | 08:21 PM
B2FiNiTY's Avatar
You can say that again.
Old Dec 3, 2001 | 08:33 PM
Mike95lude's Avatar
that is so not worth it...
Old Dec 3, 2001 | 11:31 PM
Vazquez911's Avatar
Hmmmm, I think mine weighted in at another 20-25 pounds... but I used dynomat from the front doors back. The doors such much more solid (more lexus like). Less vibration... not THAT big a difference from stock. Perhaps a nice foam pad under it all would help TONS.
Integritycaptain90
Aug 29, 2006 06:54 PM
qcktegls
Dec 23, 2004 08:14 AM
baddassduramax
Mar 3, 2003 11:49 AM
Fooman
Dec 6, 2001 03:08 PM
