HOW TO : Remove Transmission
Old Aug 20, 2004 | 07:53 PM
senpai's Avatar
Default HOW TO : Remove Transmission
This is for the people who want to save money, yet still do it right.
http://www.geocities.com/senpai_performance/
Give me comments, suggestions! Thanks!
Modified by maztur at 11:45 PM 8/20/2004
Old Aug 20, 2004 | 08:34 PM
Change's Avatar
Default Re: HOW TO : Remove Transmission (maztur)
its not workin dude.
Old Aug 20, 2004 | 08:46 PM
senpai's Avatar
Default Re: HOW TO : Remove Transmission (pSI civic)
boo, i exceeded data transfer!
Old Aug 20, 2004 | 08:51 PM
B2FiNiTY's Avatar
dood. DON'T jack up your car on tow hooks! It is not safe.
Why do you have to drain your coolant?!?
Old Aug 20, 2004 | 09:03 PM
senpai's Avatar
Default Re: HOW TO : Remove Transmission (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">dood. DON'T jack up your car on tow hooks! It is not safe.
Why do you have to drain your coolant?!? </TD></TR></TABLE>
Yea, it's not really a recommended jack point, but it works. It sees no sustained weight anyways, the jack stands do.
I drain the coolant because I remove the lower radiator hose. I suspose you don't have to, but I do it because I had to (I was in the middle of a mini-me) Also, it may be easier for "new" people to locate everything that way. it's also easier when putting the tranny back in.
Old Aug 26, 2004 | 11:13 AM
senpai's Avatar
Added the clutch install; if anyone cares
Old Aug 26, 2004 | 12:40 PM
4drEF's Avatar
Keyboard Humorist
Why did you take the distributor out?
Old Aug 26, 2004 | 12:56 PM
senpai's Avatar
Default Re: HOW TO : Remove Transmission (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">Why did you take the distributor out?</TD></TR></TABLE>
Yea, another not needed step. I like to have room and removing the distributor provides it. I better revise some steps to "OPTIONAL."
At the same time I was doing a mini-me as well, so it may not apply to everyone.
RACEPAK
11
Mar 23, 2007 01:50 PM
JDMlyfestyle
73
May 30, 2006 10:18 AM
bonta-kun
May 5, 2006 10:01 PM
Mag00n
Nov 30, 2004 12:41 PM
hOndafienD 04
Nov 27, 2004 11:23 AM
