89 CRX Si wiring problems need help.
I have an 89 CRX Si. I bought a while back but it was missing the engine harness.
So I purchased what was believed to be a 89 Si engine harenss.
Everything looks ok. MY question is.. where the wire harness comes
past the timing belt side i have 2 plugs ( a green one for the resistor box ) and a
Square one. But on my car i have the resistor box and a round plug
So i have a square on my engine harness and a round on the firewall.
This is on the drivers side where the resister box resides..
Now the square and round plug seem to be the same ( same wire colors )
just a diff style plug. Can I just repin the right style plug or do I have the
wrong harness and it wont work at all ( hoping I can just repin the one plug )
since I just finished this harness for my OBD1 GSR Swap
Ive Included 2 pictures to help out with what im talking about.
Any Help would be greatly apreciated
1989 CRX Si
1989 CRX Si Engine Harness supposely ? ?
1997 GSR Motor
Modified by QUiKSR20 at 10:49 PM 8/20/2004
1989 CRX Si
1997 GSR Motor
the green plug is for the injector box and the other portion is for the alt, iat, brake fluid level ind ect on the left side of the car mine is also round as yours is in the engine bay so your harness might be off an Integra or something that also uses and injector resistor box but its not an si or hf series and that is what you need.
my 91 dx has a round plug so you know it isnt from that. i think fastlx-i might be right in guessing that it could be from a teggy. try posting the pic in their forum and see if they know anything. 89teg's have pretty much the same wiring as the si's but some connectors could be different.
scott
scott
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skittyscott »</TD></TR><TR><TD CLASS="quote">my 91 dx has a round plug so you know it isnt from that. i think fastlx-i might be right in guessing that it could be from a teggy. try posting the pic in their forum and see if they know anything. 89teg's have pretty much the same wiring as the si's but some connectors could be different.
scott</TD></TR></TABLE>
I sure hope its not from a teg.. The guy specifically told me it was a CRX Si
and he thought a 91.. I wonder if I re pin the plug to fit right if it will work.
It would suck to loose all my time in making this harness the right way for the GSR because someone gave me the wrong harness
what you have is 88 Si harness - you can de-pin the square connector and put the round connector on the harness - just make sure the wire colors match on both sides of the connector - the square 88 connector has less wires since the 88 Si didn't have a fast idle control valve - the chassis harness side will have a darker blue wire that isn't used
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">what you have is 88 Si harness - you can de-pin the square connector and put the round connector on the harness - just make sure the wire colors match on both sides of the connector - the square 88 connector has less wires since the 88 Si didn't have a fast idle control valve - the chassis harness side will have a darker blue wire that isn't used</TD></TR></TABLE>
Awesome.. I was so scared that the harness i was sold and wired up was useless..Ill get a round plug this week and repin it..
Another thing that will need to be done - on the pass. side shock tower big round plug.
In your engine harnessm besides all other wires, it will have a Red/yel wire next to Red/white wire. The 6-wire plug next to the round plug will have Blue/yellow next to Blue/green wires. These two pairs will need to be swapped over:
Blue/yell swaps places with Red/yellow
Blue/green swaps places with Red/white.
You'll see on the car side of the plugs, there will be wiires of the matching colors, so you'll be able to verify it.
and yeah - jersey shore rules!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikitad »</TD></TR><TR><TD CLASS="quote">Another thing that will need to be done - on the pass. side shock tower big round plug.
and yeah - jersey shore rules!</TD></TR></TABLE>
Thanks man
BIG HELP.. probaly woulda been shruggin my shoulders like why isnt this thing starting up.. So after I repin the plug and swap the wires you told me to swap on the pass side i should be good to go im assuming..
PS... JERSEY SHORE KICKS *** ( 5 mins from beach ) Vegas is awesome as well.. Never been there
Going in May
Thanks man
Going in May
thecruzs2007@yahoo.com
Nov 22, 2011 11:57 AM
YOUR MOM
Nov 4, 2007 06:45 PM
mike84 CRX-GTL
Sep 12, 2005 03:45 PM
