Tachometer Problems Help
Old Aug 20, 2004 | 06:26 PM
xvietxkhmerxboix's Avatar
Default Tachometer Problems Help
Now before I start jumping into point fingers I got a question. I used to have a 99 Si cluster in my 99 hatch but sense then I have sold the cluster and now have a dx cluster. I bought a 3911 autometer tach off a ht member but the red button seem to be missing or broken, now I tried to install it so I looked up the directions
http://hp.autometer.com/instru...j.pdf
Display Button: Depressing red
button activates pointer to display
RPM while setting or verifying
shift-point.
1. Push and hold red button. Pointer will display the
tachometer's shift-point.
2. To set your desired shift-point, continue depressing
the red button, then push and turn the Shift-Set ****
until the pointer reaches the desired RPM.
3. To double check, push red set button-- pointer will
indicate your shift-point.
4. During normal tachometer operation, the Shift-lite
will activate at the exact same RPM that the pointer
indicates when red set button is depressed.
So if the red button is broken I can't set it hope you can help before I point fingers
here some pictures might help.
Pictures of the tach I bought
Picture of what it should look like
I'm not going to say who sold it until I figure out if I'm right or not but he said
(3:17 AM 8/6/2004) JohnDoe: we'll its in great working condition , only thing is the sun had faded it just a lil bit from being in the car , its been in my car for about a year ... but works great , you wont be dissapointed , if you want it let me know and i will add that it has been sold to you and ill send it to you asap ...
Old Aug 20, 2004 | 06:36 PM
hatchling37's Avatar
Default Re: Tachometer Problems Help (xvietxkhmerxboix)
What's your question? I read through that and there wasn't a tech-related question in there.
Old Aug 20, 2004 | 06:39 PM
Default Re: Tachometer Problems Help (hatchling37)
Sorry I was asking do I need that red button to set the tach to the desired rpm?
Old Aug 20, 2004 | 06:45 PM
Not necessarily. The red button just pushes in to actuate the tach setting mode. If you can push in the same area where the red button is (as in it actually goes in), then I don't see why you would have a problem other than cosmetic
Old Aug 21, 2004 | 08:37 AM
EK9Greg's Avatar
I had the same problem on mine thats why I got it for like 30$. The easiest thing to do is get something small that is metal like a cotter pin or allen key and stick it in the hole where the red botton goes. That should do the trick> good luck
94vtirozguy
Aug 1, 2020 10:47 AM
bingali
Jun 4, 2015 05:25 AM
TRIGA
Nov 23, 2009 12:29 PM
CodyC142
Apr 25, 2008 01:11 PM
sladed16y8
Feb 23, 2007 08:03 AM
