Radiator question
Old Aug 20, 2004 | 05:32 PM
mr_valentino20032000's Avatar
Default Radiator question
Ok, i am in the middle of getting everything ready for an engine swap, a DOHC ZC into my CRX. I have bought 2 radiators so far; an EG (the 1/2 size) and one i bought from http://www.radiator.com and they sent me a diffrent one from my stock one.
It has two brass...tubes that come out of the bottom and i can't use them. So this brings us to the question....
Can i just cut off the things and stuff them with JB Weld and call it a day or what? Oh yeah i'd buy another one but the engine is getting here on tuesday
Old Aug 20, 2004 | 05:34 PM
Default Re: Radiator question (mr_valentino20032000)
oops..thanks for everything in advance
Old Aug 20, 2004 | 05:55 PM
no one knows? i'm not even sure what they are for
Old Aug 20, 2004 | 05:59 PM
XrcR6's Avatar
So the second one is basically like stock with the exception of the additional 2 fittings? It's probably a provision for a tranny cooler for an automatic transmission car. In that case you can just cap/plug them off or loop them together.
ZCdohcHB's Avatar
the 2 pipe on the bottom is for the automatic transmission
i have the same thing, i just plugged it up
Old Aug 20, 2004 | 06:02 PM
Default Re: (ZCdohcHB)
Ok in that case...does your hit the front cross member? It looks like mine is going to and if i hit a bump or something they will bend off. And i don't want that to happen
Maybe i'm just being paranoid
Old Aug 20, 2004 | 06:45 PM
Default Re: (mr_valentino20032000)
to cut or not to cut..that is the question. Anyone?
Old Aug 20, 2004 | 07:55 PM
up for the evening
Old Aug 20, 2004 | 09:05 PM
CRX T-Si's Avatar
Just unscrew those two fittings off the new Rad, problem solved.
If their not screwed on then just use a hack saw and cut it off.
It's easy as 1-2-3.
EK9JSPEC
Sep 9, 2012 07:30 AM
Ride Da Fire
May 15, 2012 08:46 PM
TrackRat
Sep 16, 2005 09:03 PM
Jul 14, 2004 05:46 PM
96-EJ6 B18C
Apr 27, 2004 09:18 AM
