~~ 1997 Prelude: Need Help w/ Brakes ~~
Need new Brakes (front & back) and need new Rotors (front & back).
Any suggestions about makes or models?
Any help or advice would be appreciated.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tutin77 »</TD></TR><TR><TD CLASS="quote">{}
Thanks</TD></TR></TABLE>
In anycase I would prefer you to go with "brembo" slotted rotors. and as far as brakes go.. you would have to choose something that would fit your preference. like break dust, wear?
I prefer low dust - no noise brakes.
Thanks for the info on the Rotors. I found Brembo Rotors for $109 ... is this good or can I find better??
Thanks again in advance for the help.
- OK -
¿Where do I find cobaltfriction?
Honestly I don't understand what u mean by setups?
Wish I knew more, but I am new to this.... again, thanks for the help.
I'm running Autozone Blank Rotors (just like Brembo) with AXXIS Metal Master Pads. I can safely and honestly say... that was the best $110 I have ever spent on brakes. For another $100, I have Goodrich Stainless Steel Brakelines coming in... combine that with some nice DOT4 fluid, it should be a pretty solid setup.
No complaints for ~$200.
No complaints for ~$200.Trending Topics
I would also suggest the AutoZone blanks.
$40 for both front rotors.
Spend the money on an expensive pad.
Now...that is only if you want to race the car. If you just want new brakes. I would recommend the same rotors, but just get a cheap pad with no noise and low dust.
Don't waste your money on expesive rotors.
I use the Semi-Metallic... pretty good pad IMO. I'd say in a race situation, the ceramic... but I don't know the noise, dust, or friction properties between the two.
plain old joe shmoe carquest pads and rotors have always done the
job for me. I just never saw any reason to spend a lot of money on
overpriced ones, but that's just me.
if i wanted an upgraded brake system then i would do the legend
caliper conversion
caliper conversion
