harness conversion
Old Aug 20, 2004 | 07:49 AM
Mr.Death's Avatar
Default harness conversion
Does anyone have any info (how to) on making a obdo obd1 conversion harness? I've searched far and wide but can't find any sites. Any help is appreciated.
Thanx
Old Aug 20, 2004 | 08:15 AM
turbob16rex's Avatar
Default Re: harness conversion (Mr.Death)
i'd say save yourself the trouble of making one, and spend a few to get a quality harness. classifieds has them cheap
Old Aug 20, 2004 | 09:08 AM
Rywire's Avatar
Default Re: harness conversion (turbob16rex)
http://www.geocities.com/droppedcrxsi_wiring
I make custom harnesses, I can do whatever you need in very short turn around time.
Ryan
Old Aug 20, 2004 | 09:09 AM
RicedREX's Avatar
I bought one for $115, I have a dx its alot of help but would be absolutley perfect if you have an si/hf.
Old Aug 20, 2004 | 09:31 AM
Rywire's Avatar
Default Re: (RicedREX)
oh, you just need a conversion harness? https://honda-tech.com/zerothread?id=890675
or
http://www.jkobdconversionharness.com/
Old Aug 20, 2004 | 11:47 AM
bummster's Avatar
i'm sort of forced to do this with my main harness and engine harness being torn assunder in my dx hatch.
places with info that's worth looking over.
http://fourthgenhatch.com/mpfi.html
http://www.geocities.com/b16ap....html
http://www.hondaswap.com/forum...29360
http://www.boosted.org/ecu/COMPLETE.txt
Old Aug 20, 2004 | 11:51 AM
EL Vap133's Avatar
Default Re: harness conversion (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">http://www.geocities.com/droppedcrxsi_wiring
Ryan</TD></TR></TABLE>
Ryan knows his ****.
Old Aug 20, 2004 | 01:13 PM
Custom Rex's Avatar
Default Re: harness conversion (EL Vap133)
if u were to use a obd0 to obd1 jumper harness, how would u check your ecu codes? does it have the jumper plug built into it?
Old Aug 20, 2004 | 01:46 PM
4drEF's Avatar
Keyboard Humorist
Default Re: harness conversion (Custom Rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Custom Rex &raquo;</TD></TR><TR><TD CLASS="quote">if u were to use a obd0 to obd1 jumper harness, how would u check your ecu codes? does it have the jumper plug built into it?</TD></TR></TABLE>
You put a jumper into your stock electronic ignition advance defeat plug.
On OBD0 this plug only controls the electronic ignition advance defeat. The ECU codes blink out on the ECU cover.
On OBD1 the plug does both. You jump it and you are defeating the eletronic advance as well as setting the ECU to blink out codes on your CEL.
Old Aug 20, 2004 | 05:40 PM
Rywire's Avatar
Default Re: harness conversion (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">You put a jumper into your stock electronic ignition advance defeat plug.
On OBD1 the plug does both. You jump it and you are defeating the eletronic advance as well as setting the ECU to blink out codes on your CEL.</TD></TR></TABLE>
Thats the way to do it, or use a switch. Both work
alexb16hb
Apr 16, 2007 10:32 AM
dagimp415
May 1, 2006 09:10 AM
Crimson_Tide
Jun 29, 2005 10:39 PM
romeo619romeo
Mar 28, 2003 09:54 AM
