D15b vtec?
Old Aug 19, 2004 | 10:58 PM
Schaz's Avatar
Default D15b vtec?
okay i have been reading alot and seeing that there is a D15b vtec...i have a d15b in my CRX but i dunno where to go with it...i have 30-40 pounds of compression in cylinder 2..pretty sure its a valve seat problem cuz i poured oil in the cylinder to check the rings.....my plans so far are a SI tranny (which i heard will bolt on the d15b) and changing dpfi to mpfi..... anything else i should or have to change when doing this process please feel free to tell me....also what years of the SI tranny and mpfi should i get..i kno i sound dumb but i wanna cover my *** incase anything happends thanks fellow CRX owners!
Old Aug 20, 2004 | 01:27 AM
92integra_gs's Avatar
that is the jdm swap d15b... the other way like i said in the previous thread that you got you can got with the mini-me... z6 vtec head onto your d15b2 block... i am assuming you got a b2 block.... FYI if you got a 88 tranny... you cant reuse the flywheel and clutch w/ the si tranny... i am assuming that you got the 89-91 si tranny... but you can get a 92-95 ex/si (z6) flywheel which is 12 lbs which is lighter than 89-91 si flywheel ... as for the clutch you can either look for the 89-95 clutch... i hope i am getting thru to you....
hazrd420
Aug 3, 2007 08:58 PM
komat
Dec 18, 2004 04:27 PM
Log4n
Feb 5, 2003 08:04 PM
Proper
12
Nov 7, 2002 09:16 AM
nighthunt6
12
Oct 4, 2002 12:22 PM
