NEED MAJOR HELP, DRIVER SIDE HEADLIGHT AND CORNERLAMP really dim
Old Aug 19, 2004 | 10:11 PM
Skank_aSS_Dara's Avatar
Default NEED MAJOR HELP, DRIVER SIDE HEADLIGHT AND CORNERLAMP really dim
checked the fuses, not that, not the alternator its just the driverside only.
the driverside headlight is really dim and the driverside turn signal blinks rapidly, the left turn signal in my cluster stays on very dim also, i hit the high beam and the driverside dim light goes out unless i switch highbeam off..... this happened right after i did a 35mph hard right turn, can anybody help me and solve this error asap so i can drive at night
TIA
-dara
Old Aug 19, 2004 | 10:23 PM
Mikey-G's Avatar
Default Re: NEED MAJOR HELP, DRIVER SIDE HEADLIGHT AND CORNERLAMP really dim (dramatic_scientist)
check the wires...cause i had wires that were messed up, and it would go high and low dimmin sometimes, also happend with my turn signals, sometimes it would go fast, and then normal
Old Aug 21, 2004 | 07:56 PM
Default Re: NEED MAJOR HELP, DRIVER SIDE HEADLIGHT AND CORNERLAMP really dim (Mikey-G)
anybody else before i start tearing up my wire apart to see the defects..........
Old Aug 21, 2004 | 08:57 PM
rentacop's Avatar
Definitely sounds like a corroded wire or possibly a bad ground. The wires could be separating from the plugs.
Old Aug 21, 2004 | 10:07 PM
DJ_NeX's Avatar
Default Re: (l Hybrid l)
also could be water somewhere in the wiring...it only takes a little bit.
Old Aug 23, 2004 | 11:52 PM
Default Re: (DJ_NeX)
found out the problem, my grounding pack for the driver side area had bad grounding thanks guys
kd SOO JDM
Feb 2, 2011 04:45 PM
EM2Thrasher
Honda Civic (2001 - 2005)
May 10, 2006 06:29 PM
Toadfart
Nov 1, 2004 05:38 PM
JDMlyfestyle
Dec 2, 2003 08:25 PM
DarkCyde SI
Aug 14, 2003 12:12 AM
