GSR all motor
I have sat here the past few nights searching and reading about all motor set ups on a GSR but i would still like some intput. I need to get ordering things soon. I was thinking about Skunk 2 stage 2 cams, skunk2 valvetrain, ITR oversized pistons, maybe change the rods (need to know a good brand to go with), Apexi VAFC II, and a header (also need to know a good one). I already have intake, cat back exhaust, 7 lbs, flywheel, ACT clutch with extreme pressure plate, and ITR tranny. I know that im going to need a new head gasket and things of that sort also probably a fuel system upgrade. I want to try and stay in the 3K range though after everything is said and done. The car also will be driven as an everyday driver so it needs to be reliable. anyone that can make a list of things to check out and things of that sort would be greatly appreciated. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatOneGirl »</TD></TR><TR><TD CLASS="quote">all i can say is, GOOD LUCK in whatever you build....
thanks, i may need it.
</TD></TR></TABLE>thanks, i may need it.
u can stick with gsr rods. they should be good up to 8.5k safely maybe 9k. if u go aftermarket rods u'll have to get the oem pistons converted to floating pin
