b18a1 vs D16a6
allright....i have access to both of these motors for dirt cheap...i was wonding what advantages and disadvantages would be if i put them in a 1989 honda CRX dx...would i have to do a tranny swap or anything else that i missed please tell me thanks....
the d is lighter but unless you get a vtec head it will still be slow. it will fit pretty well. the dx tranny will work i think but its gear ratio is a bit to low for a performance car. (3.888 final drive)
The D16a6 only makes a few more ponies then the Dx motor you already have. Instead you could just use the Si tranny... that's the easiest way to make your HF or Dx faster.
But if you want a fast car, b18a1 turbo
It's research time!
It's research time!
aiight so here it is...i can use my stock motor D15b nonvtec motor...put a si tranny on it (cuz it will bolt right on) and the go drom dpfi to mpfi? anything else i can do to my car to make it fast...since i bought it for 200 i have a decent amount to work with...thanks
if you can get a cheap d16a6 and an si tranny that would be much better then still using the d15b. the d16ag is already mpfi so thats a bit less work and its a little bigger... it should go in fine and the ecu wiring wont be as hard.
so all in all....get a D16A6 motor....with mpfi on it...then find a civic SI tranny...then ill be good to go?....
1989 Honda CRX Dx
D15b (**** motor)
Bone Stock...until D16a6
Hilton,Ny
Greg
1989 Honda CRX Dx
D15b (**** motor)
Hilton,Ny
Greg
b18a1 even tho this motor weights more than the d16a6... you will get +30 hp & +30 tq... worth it if you got the money to spend for this swap... other route to go is the mini-me directions... which will give you +30 hp & the same tq as the d16a6 and you are using the same block you got the b2 block....
if you get a cheap d16a6, its already mpfi so you wont have to swap all the stuff to it like you would if you kept your d15b2. the b18a1 would be good but if you put a z6 head on the a6 block and get a turbo, you could blow lots of people away.
v-motion
10
Feb 22, 2007 05:42 AM
90da4dr
Mar 2, 2003 05:56 AM
ViperRedCRX
Jan 13, 2003 12:01 PM
xXx Justin xXx
21
May 17, 2002 03:37 AM
