Brake Pad Sizes?
Old Aug 19, 2004 | 07:40 PM
mjrage's Avatar
Default Brake Pad Sizes?
I bought a car a few months ago and I have been having this never ending saga of things that just dont match up. So the brakes are **** and I decide to get new pads tonite. The guy I bought it from said the brakes are from a 98-01 Integra discs... I go buy 98 integra pads... I get everything off, etc.. lining up the new pads, looks good, go to put the rest of the caliper back on and... the pads + rotor = too big for the caliper to fit over the top of them. Could this just be warped rotors? If I put the old **** brakes back in, they are worn far enough that it looks fine. The cylinder on the caliper which I believe is the piston wont retract, etc.. I have only changed pads on the rear of my last si and that piston retracted. This is just basically a cup back there and nothing inside of it but some rust.
WTF?
Old Aug 19, 2004 | 07:56 PM
adictionbass's Avatar
Default Re: Brake Pad Sizes? (mjrage)
you have to get something to clamp the caliper and push the piston back into the caliper. Use a big pair or channel locks. It should be farily tough to squeeze back in.
PS: make sure the boot around the the piston is seated properly!!!
BrakeExpert
Suspension & Brakes
Apr 9, 2012 05:59 PM
Dann6968
Suspension & Brakes
Mar 7, 2010 07:51 PM
BrakeExpert
Suspension & Brakes
Sep 13, 2008 09:11 AM
NoLipRacen
Apr 10, 2003 11:27 AM
blkbeast
Jan 14, 2002 12:58 PM
