Integra DA JDM 1 Piece Fog Light Question
Old Aug 19, 2004 | 05:46 PM
Endless STi's Avatar
Default Integra DA JDM 1 Piece Fog Light Question
is it true that the jdm 1 piece like the one in the pic makes the fog lights light up yellow instead of lighting up white? thanks. btw i searched.
Old Aug 19, 2004 | 06:15 PM
3.504's Avatar
Default Re: Integra DA JDM 1 Piece Fog Light Question (Bootleg R)
you have to use a yellow bulb... it doesn't have a yellow reflector if thats what you mean
Old Aug 19, 2004 | 06:25 PM
Default Re: Integra DA JDM 1 Piece Fog Light Question (3.504)
i cant get the bulb becuz i did a search and it said that 90-91 integras have a circle connector and it wont fit the new H3 55w bulb. rite now H3 55w bulbs r flat and not circle. so does neone know wat i can do?
Old Aug 19, 2004 | 06:38 PM
3.504's Avatar
http://www.nopionline.com/nopi...01993
that one works... its a gold beam. go to any autoparts store like autozone, they'll have something for you
Old Aug 19, 2004 | 06:42 PM
aite kool. thanks a lot man!
Old Aug 19, 2004 | 06:48 PM
Xsi's Avatar
Xsi
Mine use a white bulb and come with yellow reflectors inside the light itself. The bulbs I use are fairly generic ones that you can find at a lot of places.
Old Aug 19, 2004 | 07:12 PM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">you have to use a yellow bulb... it doesn't have a yellow reflector if thats what you mean</TD></TR></TABLE>
Incorrect.
The JDM 1 piece hadlights use clear fog light bulbs and light up yellow because of a translucent yellow cover.
Old Aug 19, 2004 | 07:41 PM
mr.beeks's Avatar
Default Re: Integra DA JDM 1 Piece Fog Light Question (arw321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 &raquo;</TD></TR><TR><TD CLASS="quote">
yeap there is a yellow lens in there....
Old Aug 19, 2004 | 08:26 PM
Xsi's Avatar
Xsi
There are also glare guards but if you pull your lights apart like me you can take them out.
Old Aug 19, 2004 | 09:43 PM
3.504's Avatar
Default Re: (Xsi)
heres a pic off g2ic of the inside of a jdm 1piece fog (they were removing the glair gaurds) as you can see, the bulb is yellow and there is no reflector. these are the stock jdm 1 pieces.
heres the link: http://www.g2ic.com/tegtips/lighting/22.html
Modified by 3.504 at 7:05 AM 8/20/2004
Old Aug 19, 2004 | 10:05 PM
DA9RsIntegra's Avatar
Default Re: (3.504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">heres a pic off g2ic of the inside of a jdm 1piece fog (they were removing the glair gaurds) as you can see, the bulb is yellow and there is no reflector. these are the stock jdm 1 pieces.
Modified by 3.504 at 7:03 AM 8/20/2004</TD></TR></TABLE>
I hate to be frank, but you are a ******* idiot.
Taken from the EXACT same "Teg tips" this dumbass got this pic from..
"Right behind is the yellow lens which alot of people hate (including myself). Just push down on the base and turn counter-clockwise to pull it out."
Old Aug 19, 2004 | 10:06 PM
Toadfart's Avatar
If I were to paint the inside for black housing mod, what area do i paint?
Old Aug 19, 2004 | 10:15 PM
Default Re: Integra DA JDM 1 Piece Fog Light Question (Toadfart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toadfart &raquo;</TD></TR><TR><TD CLASS="quote">If I were to paint the inside for black housing mod, what area do i paint?</TD></TR></TABLE>
http://www.g2ic.com/forums/sho...black
Old Aug 19, 2004 | 10:18 PM
3.504's Avatar
Default Re: (DA9RsIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9RsIntegra &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for the hatred. a simple "if you would have read the tip, you would have seen the reflector was removed before this pic" would have worked.
2 people up above said this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">Mine use a white bulb and come with yellow reflectors inside the light itself. The bulbs I use are fairly generic ones that you can find at a lot of places.</TD></TR></TABLE>
Incorrect.
i wanted to also point out in the pic that there's a yellow bulb there
Old Aug 19, 2004 | 10:26 PM
Default Re: (3.504)
Okay, okay.. don't wanna start a e-thug fest, but then again, you so clearly state that 2 people said it... well then why do you say otherwise? And secondly, if the 1-pieces are "stock" I highly doubt the bulb is yellow, in fact, it isn't.
"DA9RsIntegra- whose clean 1-piecers were smashed in a starbucks parking lot 1-1/2 ago
Old Aug 19, 2004 | 10:35 PM
importdude2000's Avatar
they arent yellow the
h3 35w stockers do not make it yellow
there is a yellow TUBE as seen in the picture up top
and here is a picture i snaped
3.504's Avatar
the g2ic tip is a little unclear on some things... sorry if i had a little mislead info. but i went back and read the tip, and the tip doesn't say anything about that being a different bulb. it also doesn't show a pic of the reflector, so i missed it on my initial search.
i stated that: there was no reflector (which i was wrong) and there was a yellow bulb. i found that pic (being the only pic i could find) and it had a yellow bulb. g2ic does say they are stock jdm 1 pieces on there, but they didn't say thats a different bulb... it says there are plans of running a different bulb, but the pictures dont tell a story of bulb replacement. that probably where i got confused.
thanks for clearing it up. next time, if you dont mind, tone down the harshness.
Old Aug 19, 2004 | 10:37 PM
3.504's Avatar
Default Re: (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">they arent yellow the
lol, that doesn't look like a reflector, looks more like a bulb condom
Old Aug 19, 2004 | 10:40 PM
Default Re: (3.504)
did i say it was a relector?
i said its a bulb COVER that makes it yellow
ask me anytihng about jdm 1peices
i call myself jdm 1peices king
Old Aug 19, 2004 | 10:41 PM
3.504's Avatar
i was laughing about everyone above calling it a reflector.... you just helped my point a bit
Old Aug 19, 2004 | 10:48 PM
Amkread's Avatar
Default Re: (3.504)
damn importdude, thats a lotta 1piecers laying around, how bout you send me a set
Old Aug 19, 2004 | 10:51 PM
Default Re: (Amkread)
that was my first batch... i had 3-4 batchs
sold em all
now iam down to 1 set 3 pass sides
heheh
easy money
Old Aug 20, 2004 | 11:10 AM
kool thanks a lot everyone.
143MYVTECEF
11
May 29, 2007 08:40 PM
cilvia
35
Jun 29, 2006 11:53 PM
PolyPill
Sep 7, 2004 08:25 PM
1Tym
Jun 2, 2003 06:20 AM
