Exhaust Suggestions
I'm looking for an exhaust, I didn't buy my integra yet so i just want some general or brand name suggestions, I want an exhaust thats quiet untill the rev's get high or you floor it, kind of like an intake or a some what of a sleeper exhaust i guess you can compare it too, thanks
You must use the search feature here. You are asking a very general question. I will try to help you out though.
Before you get into things, you want to figure out your goals for your car. Do you want some high horspower high boosting turbo car? A pretty powerful all motor car? Something just a little quicker than stock?
Your exhaust and intake must conform to these requirements. For example, if you get an intake now, and then get a turbo later, you'll have to throw away/sell the intake. If you get a small diameter exhaust now with a nice tone, everything will change if you want a turbo setup.
I did search and found nothing that can help me
I am looking for a high boost high hp so I would be most likely be purchasing a 2.5
Can you just tell me some exhaust I may want to look into?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Waiting For My Tegra »</TD></TR><TR><TD CLASS="quote">I am looking for a high boost high hp so I would be most likely be purchasing a 2.5
In that case, a 2.5 might be a bit too small. How much horsepower are you looking to reach? 250whp? 300whp? More? Less?
Generally, any straight through exhaust canister setup will be good for that. Look at Greddy, Thermal R&D, Apexi (N1 styles).
Keep in mind, these setups will be LOUD LOUD LOUD without the turbo. You will lose a bit of power if you don't have the turbo actually on the car yet. Once the turbo goes on, it is a restriction in itself, so the system will quiet down.
A general rule is any straight-thru muffler will be very loud. A chambered exhaust will be quieter.
alright man, that helps alot thanks I was going to get an N1 for my accord but im selling because it could not complete the goals I have for my car, Im looking for around 300 horse power, and the accord is way to heavy 3020 and had so much i didn't need, But It was good to learn to shift, To get what i wanted out of my accord i would need an engine swap h22a, then need to strengthen the internals, turbo with high boost, new axels, suspension totally redone,
BlackNoise
Jun 18, 2006 07:46 PM
jmm611
May 9, 2006 12:39 PM
