2 questions about a da integra
Old Aug 19, 2004 | 03:20 PM
cu_jarrett's Avatar
Default 2 questions about a da integra
1. How do you take out the middle headlight?
2. do you need to run two fans after removing the a/c
Old Aug 19, 2004 | 03:25 PM
PhantomSTi's Avatar
Default Re: 2 questions about a da integra (cu_jarrett)
Can't answer the first question, but as for the second one, you don't have to run the AC fan. I'm actually running a PWR Civic Half Radiator, I ghetto rigged up a bracket and mounted the AC fan onto my Half Radiator for clearence for my turbo.. But, I just got a slim 12" fan so... But cooling was never an issue.
Old Aug 19, 2004 | 03:46 PM
DA9RsIntegra's Avatar
the cooling ques. was answered. so.. are you asking about the "headlight" the main one, or the foglight? If its the bulb, the headlight can be unscrewed from inside the engine bay, as for remiving the housing itself, you have to take off the bumper to get to the bottom bolts..
Old Aug 19, 2004 | 03:50 PM
WhitEdRift's Avatar
Default Re: 2 questions about a da integra (DA9RsIntegra)
I completely took apart my headlight assembly a couple of times and now I forget lol. But I could have sword I got the headlights out without removing the bumper, but then again the first time I did it I removed the bumper. I have the USDM version and I believe I was able to remove the whole like assembly without removing the bumper. However I left the bracket that holds each individual light fixture on.
Old Aug 19, 2004 | 04:27 PM
Default Re: 2 questions about a da integra (WhitEdRift)
We'll your way might have worked because you removed the bracket from the actual housing. If you are installing JDM one piecers or just removing the stock ones, most people removing the entire set-up as a whole. Either way should work (it seems like it did last time). Good luck
Old Aug 19, 2004 | 08:40 PM
WhitEdRift's Avatar
Yeah if you do remove the whole assembly it would be easier to take off the bumper. Only problem with that is getting it back on. My '91 has this metal piece that hooks onto it's partner piece on the frame of the car and that was very difficult to get back together. Now it just doesn't sit the same. hehe
96CivicEXSedan
Jul 28, 2015 03:20 PM
TylerC161
Sep 23, 2006 03:47 PM
londonsupra
Jun 30, 2006 05:22 AM
diyer
Feb 10, 2005 08:37 AM
6MTV6
Jun 7, 2004 07:41 AM
