Any suggestions on this? easy fix or no?
Old Aug 19, 2004 | 01:22 PM
brent_G's Avatar
Default Any suggestions on this? easy fix or no?
So the bracket broke off my y1 tranny (clutch bracket) Thikn this would be an easy fix?
Old Aug 19, 2004 | 03:46 PM
B18C1CYA's Avatar
Default Re: Any suggestions on this? easy fix or no? (brent_G)
i would make a new bracket to mount some where else on the tranny , lets going to be your best bet
Old Aug 19, 2004 | 04:14 PM
4CFED's Avatar
Fairly easy fix. Just need to find a good welding shop that will do it. I've been getting a lot of 1st gen B16's that break off the motor mount underneath the timing belt cover. We simply build up the area around were the holes are broken, smooth it out, drill, tap, and insert Timer-Serts. Time-Serts are like Helicoils, but they are a solid threaded steel insert. The part that was broken is as good as new. Here is a pic.
Old Aug 19, 2004 | 04:27 PM
brent_G's Avatar
Default Re: Any suggestions on this? easy fix or no? (4CFED)
yeah thats what iw as thinking would be a good idea also. Just build the hell outta it, then retap it. But thinking about it i will prolly have somone make me some sorta metal bracket that i will run from the mount area to hold the clutch bracket.
Any more ideas are welcome
Old Aug 20, 2004 | 06:42 AM
mmuller's Avatar
Mad Scientist
i have had 2 tranny's welded like that by the torque mount, take it to a place that know what they are doing and they'll fix it no problems.
shadowstylz
Jan 28, 2019 09:14 PM
93JDM_H22
Jul 1, 2010 12:04 AM
y0whuddupb
Welding / Fabrication
Sep 26, 2005 03:37 PM
AzntstyleZ
Jan 23, 2005 08:37 PM
Chugger
Oct 27, 2002 10:05 PM
