need help... alternator belt snapped while on highway.. now car wont start
my alternator belt snapped while i was on the highway today... well i got he belt changed and the car still would not start.. i tried jumping it and push starting.. but still doesnt start.... when i jump it.. it cranks and just doenst start.. when i push start it... it actually tries to start but just sputters a bit and dies out... anyone has had any experience like this before?
[Modified by wdyno, 2:14 AM 12/4/2001]
i am getting spark... and plenty of fuel... and i tried changing the distributor already.. and the ecu and changed the spark plugs
would a bad alternator have any effect on the car starting???theres plenty of power in the battery....
would the flywheel be a problem??? my throw out bearing was kinda bad already... can the clutch be a problem too.. cuz before the car was broke it made a lil metal hitting noise.. i just changed the starter today.. and it still doesnt crank up.. did a compression test... came out 170ish on all cylinders.... but part of this is because the car doesnt crank all the way.... any ideas???i checked all the fuses.. but how do u check the cam gears????
[Modified by wdyno, 2:17 AM 12/4/2001]
[Modified by wdyno, 2:18 AM 12/4/2001]
anybody know if a bad injectors or bad fuel pump be a porblem to starting up.. when i say bad.. i mean that it flows too much fuel... cuz theres plenty of fuel on the spark plugs when i pull them out... but this might be caused by the multiple times that i tried to start the car..
you sure your getting ENOUGH spark? cause if theres fuel all over the spark plugs....i would think your not getting enough spark.
