B16 pistons in GSR...do i need to tune?
Old Aug 19, 2004 | 02:28 AM
davejj40's Avatar
Default B16 pistons in GSR...do i need to tune?
I searched and found lil information on this...at most its vague. I would think if theres higher compression one would need a tune to improve HP and drivability. Do the B16 pistons cause the motor to run leaner than usually? btw i use 91 octane since im in SF..... Well anyhows I was think about a VAFC 1 cause its cheaper, but honestly the VAFC2 seems kinda sick with tis 2 map settings and smaller increments, not mention the cool looking lights hahaha...Thx in advance for the help....much appreciated
Old Aug 19, 2004 | 02:31 AM
davejj40's Avatar
Default Re: B16 pistons in GSR...do i need to tune? (davejj40)
hmmm bump
Old Aug 19, 2004 | 04:58 AM
m R g S r's Avatar
Don't use a VAFC to tune your car, and the SLIGHT compression bump will not REQUIRE you to re-tune, but it may help if you do.
Old Aug 19, 2004 | 10:49 AM
davejj40's Avatar
Default Re: B16 pistons in GSR...do i need to tune? (m R g S r)
the car runs well but sometimes they are small bogs when I hit the gas.....I was gonna richen up the fuel a lil with a FPR first but found out my friend had a VAFC....O well we ll see if this works....I already tried a new fuel filter in hopes that the bogs would go away....
Old Aug 20, 2004 | 01:30 PM
davejj40's Avatar
people say to use vafc and many others say no....I bought it for 140 so I said y not...Im gonna try to install this weekend and see if I can get some dyno time. The throttle is choppy so Im wondering if im a lil lean in the lower gears...any advice
Old Aug 20, 2004 | 01:32 PM
patmcd's Avatar
a little tuning wont hurt it, so you might as well.
Old Aug 20, 2004 | 08:57 PM
darrinbrewer's Avatar
people! what are you talking about, a "little bump in compression"
b16 pistons make almost 11.3:1!..
thats a lot higher than the stock gsr 10:1 ...with GOOD tuning you just might squezze by on pump gas(93 at that)
if you get ITR pistons,,then massive tuning isn't needed..it's just 10.8:1..i got my FPR turned up a little till i go to the dyno..plugs are looking good
(i got itr pistons in my gsr)
here's a pretty acurrate compression calcualator:http://www.c-speedracing.com/h...c.php
Old Aug 21, 2004 | 06:33 PM
davejj40's Avatar
Default Re: B16 pistons in GSR...do i need to tune? (darrinbrewer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darrinbrewer &raquo;</TD></TR><TR><TD CLASS="quote">people! what are you talking about, a "little bump in compression"
here's a pretty acurrate compression calcualator:http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
thats wat i thought was going on....we only have 91 in SF, so Im betting theres pinging at times...but when I backed off the timing the car ran too shitting....I can barely hear ping most times. I got the VAFC and now Im trying to get a FPR
Old Aug 21, 2004 | 09:25 PM
kNOwLedGeDA9
Guest
Posts: n/a
darrinbrewer: It's good to know that there are other ppl out there that know their stuff.
davejj40:which B16A pistons are you putting in??? PR3 or P30? Like darrinbrewer said the P30's will put you a smidge over 11:1, and with 91 octane gas you might want to adjust the timing to compensate for the lack of 100 octane gas. PR3's might be a better choice if you want the car to run like a stock motor. If you are changing camshafts, then i say get the P30's as 11.3:1 compression is good for race cams that tend to have high overlap, which reduces dynamic compression at high revvs.
Old Aug 22, 2004 | 10:58 AM
davejj40's Avatar
Default Re: B16 pistons in GSR...do i need to tune? (kNOwLedGeDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kNOwLedGeDA9 &raquo;</TD></TR><TR><TD CLASS="quote">
davejj40:which B16A pistons are you putting in??? PR3 or P30? Like darrinbrewer said the P30's will put you a smidge over 11:1, and with 91 octane gas you might want to adjust the timing to compensate for the lack of 100 octane gas. PR3's might be a better choice if you want the car to run like a stock motor. If you are changing camshafts, then i say get the P30's as 11.3:1 compression is good for race cams that tend to have high overlap, which reduces dynamic compression at high revvs.</TD></TR></TABLE>
I have no idea what pistons they are...Im guessing P30's....The timing issues are apprent becuase of slight pinging at 16 degrees, so would a tune also compensate for this bogging, by adding more fuel?
Old Aug 22, 2004 | 11:56 AM
JTurbo's Avatar
hey i would go with ctr pistons and Toda spec c cams, and a few other things. but when u put these pistons in tune with hondata, and 440cc injectors. may sound big but it gives u more room to tune correctly.
Old Aug 22, 2004 | 08:17 PM
davejj40's Avatar
Default Re: (JTurbo)
CTR would be nice....but I have the B16 in them already, and just put in a half year ago....looking for a tuner in norcal...suggestions?
Humble Performance
Oct 1, 2005 09:23 PM
Suck my DX
Aug 25, 2005 09:16 AM
monkmonkman
Apr 4, 2004 10:05 PM
ViXoN Hatch94
Mar 24, 2004 11:56 PM
