Outlaw Engineering gasket on B18CR
Old Aug 19, 2004 | 01:50 AM
sylvain's Avatar
Default Outlaw Engineering gasket on B18CR 56K warning
Hi, i just come to buy a thermobloc kit for my 98' EUDM Integra type R.
I just want to know your experiences with this kit: dyno if possible on the same engine. And if some of you have some tips to fit it easier.
Thanks
Modified by sylvain at 8:56 PM 8/31/2004
Old Aug 19, 2004 | 04:39 AM
Philly_NBP_R's Avatar
Default Re: Outlaw Engineering gasket on B18CR (sylvain)
what is this gasket for?
is it like the hondata Intake Manifold gasket?
Old Aug 19, 2004 | 04:52 AM
sylvain's Avatar
Default Re: Outlaw Engineering gasket on B18CR (Philly_NBP_R)
Yes but in the kit you have all the gaskets, thremo bloc for IM, TB, IAC valve, all the nuts, bolts.....
Old Aug 19, 2004 | 09:24 AM
confidence's Avatar
could you give us a review after you put it on? i was looking at that setup a while back. i'd also like to know how long the install takes and how difficult it is, if at all
Old Aug 19, 2004 | 10:29 AM
sylvain's Avatar
Default Re: Outlaw Engineering gasket on B18CR (snail)
Ok, no problem, i'll make a lot of pics, so it will take a few more time.
Old Aug 19, 2004 | 08:39 PM
red civic standard's Avatar
I have the outlaw engineering kit on my b18C. Very easy to install. Good directions. The kit comes with a IM gasket, TB gasket and IAC gasket.
Don't know if it gained my any whp.
Old Aug 19, 2004 | 11:51 PM
sylvain's Avatar
Default Re: Outlaw Engineering gasket on B18CR (red civic standard)
Have you bypassed all the coolant (TB and IAC) ?
Do you feal any power difference ?
Old Aug 20, 2004 | 04:59 AM
the coolant still goes to the TB and IAC. That is why you use the outlaw gasket on the TB and IAC....to shield the heat from the coolant from the manifold.
I put the gaskets on over the winter with a bunch of other mods, so I can't tell the difference.
Old Aug 20, 2004 | 01:02 PM
Renegade's Avatar
I picked one up a while back, been debating to take the mani off to install.
The 2 bolts on teh bottom are a bitch to reach.
Been working on the suspension as well, I plan to dyno tune when I get some TODA Bs and then install the gasket and dyno run again. May not be for a few months still.
Old Aug 31, 2004 | 10:55 AM
sylvain's Avatar
Thats good, i finish intall it, the manual is very good, all information are detailed perfectly.
Time need for operation: 5 hours !!!
Here is the result:
Old Aug 31, 2004 | 11:00 AM
Dan GSR's Avatar
i would replace those hoses on the catch can, they will get soft from heat, and collapse
Old Aug 31, 2004 | 11:19 AM
WAFFLES's Avatar
Default Re: Outlaw Engineering gasket on B18CR (Dan GSR)
I have that kit. I have had a few of the intake manifold bolts and the IACV bolts become loose. Other then that I like the kit.
Old Aug 31, 2004 | 04:31 PM
an2ny888's Avatar
noticed any gains? was it worth the 5 hour install?
Old Sep 26, 2004 | 08:47 AM
sylvain's Avatar
Default Re: Outlaw Engineering gasket on B18CR (an2ny888)
Definitly no worth the install time, i don't fell any difference, but now the weather is about 14°c so i'll make some new chrono between 100 to 200kph to see the diffrence.
Before kit i was at 14s for the 100-200.
Old Sep 26, 2004 | 09:02 AM
Misfit's Avatar
thank you for being honest.. its hard for people to do after spending money
Old Sep 26, 2004 | 09:09 AM
Chubz's Avatar
Default Re: Outlaw Engineering gasket on B18CR (misfit)
honestly i have the Hondata IM gasket, and i did the coolant bypass, thats where i felt the difference.
Old Nov 30, 2005 | 08:59 AM
ITRnorway's Avatar
Default Re: Outlaw Engineering gasket on B18CR (Chubzilla)
bypass the coolant?
can someone care to explain why and how?
Old Nov 30, 2005 | 09:01 AM
Dave_B's Avatar
It lowers the temp in the intake thus giving you a colder intake charge temp. Given the same volume of air the colder air is more dense. More dense air has more oxygen and thus creates more HP. Or so it is said.
Old Nov 30, 2005 | 09:48 AM
DC2 to AP2's Avatar
Default Re: (Dave_B)
where can i get this gasket kit? is it better then the hondata one?
btw... FACOM tools are awesome! love mine
Old Nov 30, 2005 | 01:15 PM
ITRnorway's Avatar
Default Re: (imola-red dc2)
okay but what should be done to the coolant hose then? i asume it has to go somwhere and not just block it (pressure would build up?)
Old Nov 30, 2005 | 01:19 PM
nholmes's Avatar
Holy old thread batman, it lives!
Old Dec 1, 2005 | 12:14 AM
ITRnorway's Avatar
yepp, have to do searching sometimes before i start a new thread
Old Dec 2, 2005 | 04:23 PM
Pondus's Avatar
Default Re: (CRXnorway)
just bypass the TB, that way it will not get heated up by the coolant.
Old Dec 2, 2005 | 05:51 PM
visi0n's Avatar
loop the coolant hose to the throttle body, then you will have no need for the throttle body gasket.
cleo7
Jul 9, 2015 02:31 PM
actionfigure
Jan 7, 2007 07:06 AM
pip9
Mar 20, 2006 07:11 AM
EGhatch33
Dec 24, 2005 03:38 PM
tremor86
Jan 20, 2004 12:48 AM
