94-97....update f and r bumpers to 99+?
you'll need the front bumper, rad support, fenders, and headlights, the rear will bolt straight up though
A friend did the conversion, I saw all that needs to be changed.
1) 98+ front bumper
2) VERY IMPORTANT. 98+ front bumper foam absorber, the 94-97 piece is a little smaller and 1/4 inch short; therefore it will wobble and If someone back into ur front a few times, it will either dent or crack if you're unlucky because there's a gap between he bumper and the foam reinforcer.
3)98+ bumper lens. and NO u don't need the supports. why do people keep saying that, because the new bumper comes with the support
4) 98+ headlights
5) 96+ power mirrors
6) NO need to modify radiator support unless u want to go JDM. USDM just bolts right on.
7) 98+ rear bumper. and Yeah, the 94-97 rear foam absorber will be okie, but the 98+ ones are different. It has grooves that hold the bumper in place. The new rear bumper has an indented slit/or lip there, It will sit right into those grooves, therefore a better fit. once again, the 94-97 will fit.
8)98+ tail lights
if you have all these, also go for the OEM body kit as well.
exterior is covered, interiour is another story.
[Modified by VTssblueEC, 10:06 PM 12/3/2001]
1) 98+ front bumper
4) 98+ headlights
8)98+ tail lights
recon23
Nov 26, 2007 06:10 PM
weakGOODJunKieS.com
Jan 6, 2003 10:36 PM
me...search function
