steel wool?/
Old Aug 18, 2004 | 11:23 PM
e g - s i x's Avatar
Default steel wool?/
where can i buy steel wool pads??
or the steel wool for the drills where i attach it on.
i'm trying to polish my rims.
Old Aug 18, 2004 | 11:42 PM
speedymon's Avatar
Default Re: steel wool?/ (aznxlunatik)
You can buy steel wool pads at Home Depot or Lowes. They'll have a selection of course to fine. They also might have the tips you're looking for. If not look in the tool section and find a dremel with polishing kit.
Also might look into sandpaper.
Old Aug 19, 2004 | 12:40 AM
IVI's Avatar
IVI
i dont think youd wanna polish your rims with steel wool or sandpaper.
Old Aug 19, 2004 | 06:09 AM
dFreezy's Avatar
Default Re: steel wool?/ (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">i dont think youd wanna polish your rims with steel wool or sandpaper.
very fine sandpaper will get metal looking new again...i used 1500 grit on my header and made the stainless steel reappear from the bronze color and stains that were consuming it
Old Aug 19, 2004 | 06:22 AM
juicy.fn's Avatar
Default Re: steel wool?/ (bl@sterVT)
yeah i dunno bout steel wool but fine sandpaper will do
Old Aug 19, 2004 | 08:13 AM
debogsr's Avatar
Default Re: steel wool?/ (juicyfn)
do you have to use the fine sandpaper to take off the clearcoat, or can you take that off with a lower grit, then move to the fine grit for the metal?
Old Aug 19, 2004 | 08:24 AM
Padawan's Avatar
Darth ModerVader
If the wheels are painted, just use Aircraft Stripper to bring them to bare metal. They surface underneath should be very clean and smooth.
Old Aug 19, 2004 | 08:38 AM
debogsr's Avatar
Default Re: steel wool?/ (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">If the wheels are painted, just use Aircraft Stripper to bring them to bare metal. They surface underneath should be very clean and smooth. </TD></TR></TABLE>
oooooooooooooooooo, good idea thanks
Old Aug 19, 2004 | 09:01 AM
97TegraLS's Avatar
Default Re: steel wool?/ (debogsr)
Steel Wool comes from in these grids:
3 = course
2 = medium
1 = fine
0 = very fine
00 = buff
000 = polish
ef93si
Jul 9, 2006 04:23 PM
B16Acrx90
Dec 7, 2005 08:05 PM
B_series_
12
Jul 31, 2005 07:37 AM
mhx
Jul 6, 2004 07:24 AM
acteg94
Jan 30, 2004 03:01 PM
