Gauge cluster
Old Aug 18, 2004 | 11:13 PM
speedycivic91's Avatar
Default Gauge cluster
i have a 91 HB STD and i want to change my gauge cluster into SI gauge cluster, do you think it will work though? need help!
thanks..
Old Aug 18, 2004 | 11:15 PM
hatchinprogress's Avatar
Default Re: Gauge cluster (speedycivic91)
yes it is a direct swap! tank out your cluster and put the si one in the same way that your old one was
Old Aug 18, 2004 | 11:22 PM
Default Re: Gauge cluster (hatchinprogress)
so all the wirings are compatible? like the rpm?
Old Aug 19, 2004 | 02:49 AM
Amkread's Avatar
theyre all compatible, just unplug the harnesses and replug into the new cluster, itll look exactly the same
Old Aug 19, 2004 | 04:58 AM
viper_2_4's Avatar
they are compatible as long as you get a 90 or 91, if you get an 89 or 88 you have to do some rewiring........also the housing is a bit different....
Old Aug 19, 2004 | 05:02 AM
manson's Avatar
Default Re: (civiccxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccxr &raquo;</TD></TR><TR><TD CLASS="quote">they are compatible as long as you get a 90 or 91, if you get an 89 or 88 you have to do some rewiring........also the housing is a bit different....</TD></TR></TABLE>
yup just make sure you buy a 90-91 cluster.
90 civic hb
Jul 15, 2007 03:18 PM
need4jdm
May 4, 2007 12:59 AM
calinomad
Sep 22, 2006 10:58 PM
kizner
Dec 30, 2005 05:44 PM
sxecustoms
Oct 21, 2003 11:15 PM
