B20B swap into DA: need some help
Old Aug 18, 2004 | 10:25 PM
BaGGed HoNDa's Avatar
Default B20B swap into DA: need some help
besides the engine, what other things will i be needing? im buying the engine here soon and i dont want to tear out the b18a and start putting the b20b in and run into a problem.. so what all will i need for this swap?
thanks guys!
Old Aug 18, 2004 | 10:37 PM
3.504's Avatar
Default Re: B20B swap into DA: need some help (BaGGed HoNDa)
you dont need anything, all parts from your LS will bolt up to the b20. you'll just need the b20 motor.
the only thing you would need is maybe replacement parts if you run into some stuff thats bad, like i had to replace my motor mounts cause the rubber innards fell out when i took my LS out.
good thing to do is all the maintance items. spark plugs, wires, cap, rotor, fuel filter, new oil filter, fill everything with fresh fluid... then that'll be basically it.
Old Aug 18, 2004 | 10:50 PM
Cjsls's Avatar
Default Re: B20B swap into DA: need some help (3.504)
timing belt/water pump/tensioner. its soo much easier when the motor is out of the car. good luck man.
Old Aug 18, 2004 | 11:34 PM
ok, cool. thanks guys
Old Aug 19, 2004 | 12:35 AM
3.504's Avatar
Default Re: B20B swap into DA: need some help (Cjsls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cjsls &raquo;</TD></TR><TR><TD CLASS="quote">timing belt/water pump/tensioner. its soo much easier when the motor is out of the car. good luck man.</TD></TR></TABLE>
knew i was forgettin somethin, thanks
CampsDb7
May 21, 2012 10:18 AM
adam00
Jul 10, 2008 12:14 PM
ls_hatch
Jun 29, 2006 09:00 AM
Vinhtran17
Apr 10, 2005 10:11 AM
CompanyFlow
Feb 6, 2005 03:31 PM
