Honda S2000 Honda S2000
My S2K is TICKING VERY VERY LOUD.........WTF..........
Old Dec 2, 2001 | 06:32 PM
Smokin_S2K's Avatar
Default My S2K is TICKING VERY VERY LOUD.........WTF..........
Hey, um yeah, that's right, I'm wondering what the hell it is, and I hope it's not the Head.......my car has plenty of oil. This crap kinda started when it seemed as though I was hitting fuel cut @ 5000RPM then 7000RPM then VTEC would kick in @ 8000RPM in 1st gear. In 2nd gear, VTEC never kicked in. I went to Honda Cars of McKinney and they said it could be my computer on Sat. But Sat. night as I pulled into my apt. complex, I noticed a loud ticking noise coming from the top of my engine, dead center. The noise gets louder and faster as the RPM's go up, hell it even happens in Neutral. It's going back to the dealership on Mon, b/c that's when I had an app.
Brian Day
Old Dec 3, 2001 | 03:20 AM
integra2000's Avatar
New User
Default Re: My S2K is TICKING VERY VERY LOUD.........WTF.......... (Smokin_S2K)
bring it to your dealer, ask them to check the clearances on the valves, my integra was doing the same thing. Well, actually, i noticed it, my friend who is a honda tech. never until he pulled the valve cover, then he checked and some were off. that sounds like what it is, nothing to be alarmed over! Do you bring it up high in the rpms alot?
Old Dec 3, 2001 | 10:42 AM
Big Phat R's Avatar
You may have "smoked" a bearing from abuse.
Bring it to the dealer.
Old Dec 3, 2001 | 06:50 PM
jteasy's Avatar
New User
Default Re: My S2K is TICKING VERY VERY LOUD.........WTF.......... (Big Phat R)
what kind of bearing would cause such a ticking
Old Dec 4, 2001 | 06:56 AM
Greyout's Avatar
Default Re: My S2K is TICKING VERY VERY LOUD.........WTF.......... (JTEASY)
rod bearing.
I did the same thing - but it was because I ran out of oil. VTEC also won't engage when you run it dry (no oil)
Old Dec 4, 2001 | 09:20 AM
Big Phat R's Avatar
rod bearing.
To fix it requires removal of the crankshaft (mainly for inspection) and new bearings - followed by a new break-in period.
Old Dec 4, 2001 | 10:51 AM
jteasy's Avatar
New User
what if I just pull the rods and replace the bearings without pulling the crank, is it certain that if there is damage to the bearings that there will be damage to the crank. I hope not.
Old Dec 7, 2001 | 10:47 AM
Smokin_S2K's Avatar
I went to the dealer, but they don't know what the problem is. They are just replacing the entire engine, tranny, rear taillight asymbly b/c of condensation, and my two front seats, b/c you could see the seams splitting. I'm going up there today b/c the Service/Parts Director who is one of my ex-bosses trying to screw me, wants to talk to me.
Old Dec 8, 2001 | 06:25 PM
project_DC2's Avatar
Good luck on talking w/ the head honcho! (He must be a fat !@#$)
Old Dec 9, 2001 | 01:34 PM
B2FiNiTY's Avatar
Almost getting a brand new car eh..
Old Dec 13, 2001 | 09:44 AM
meat's Avatar
Default Engine
Your engine probably suffered from a failed #4 cylinder. It is a "common" problem that shows itself with a very loud tick.
See http://www.s2ki.com and do a search.
Old Dec 13, 2001 | 03:39 PM
jteasy's Avatar
New User
Default Re: Engine (meat)
what does that mean, failed a cylinder
Old Dec 14, 2001 | 06:30 AM
meat's Avatar
Default Re: Engine (JTEASY)
Several people had oil starvation to Cylinder #4. This results in some very bad things in there.
Do a search for this on http://www.s2ki.com as it has been discussed often.
Old Dec 20, 2001 | 11:31 AM
Jason Saini's Avatar
Collapsed piston apron... it's happened to quite a few s2k's. The apron of the piston collapses and the piston then rattles around in the cylinder and scores up the walls. If you search on s2ki.com in the forums there are pictures of the damage. Honda is warrantying the short blocks.
h0ndaSi
Honda Civic (2006 - 2015)
13
Oct 30, 2012 04:56 PM
zex_cool
May 13, 2008 09:48 PM
spammy123
11
Dec 3, 2007 12:11 PM
walsh22
Jun 3, 2007 10:59 AM
