b16 question
Old Aug 18, 2004 | 06:57 PM
91sihatchback
Guest
Posts: n/a
Default b16 question
yea iam gonna buy my timing belt and water pump tommorrow for my swap my stupid question is do i buy those parts for a 94 del sol vtec or do i buy those parts for a 99-00 civic si ? or does it really matter? i just wanna make sure i get the right parts for my swap...i just got the rear "t" bracket from a 90-93 da that i posted up earlier about and i got a throttle cable too!! all for free at my friends junk yard......
Old Aug 18, 2004 | 06:59 PM
AaronJ's Avatar
Default Re: b16 question (91sihatchback)
Just get the timing belt and the water pump for a 99 si. Go to http://www.prostreetonline.com they have a special for that kit-i got mine for 177.00 with free shipping
Old Aug 18, 2004 | 07:00 PM
eda6's Avatar
it doesn't matter because they're both b16's.
Old Aug 18, 2004 | 07:02 PM
EL Vap133's Avatar
Default Re: b16 question (eda6 hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hb &raquo;</TD></TR><TR><TD CLASS="quote">it doesn't matter because they're both b16's.
Old Aug 18, 2004 | 07:03 PM
Fleas_Ef's Avatar
what he said
Old Aug 18, 2004 | 07:11 PM
91sihatchback
Guest
Posts: n/a
thanks guys...this is my first swap so iam kinda worrying about everything and making sure i get everything done
Old Aug 18, 2004 | 07:20 PM
X-Static's Avatar
Default Re: (91sihatchback)
yeah i was a lil paranoid on mine too...
ive been running my stock plugs and wires since the swap and its def. time to change them, is it the same principle? b16 is a b16 is a b16?
Old Aug 18, 2004 | 07:27 PM
eda6's Avatar
Default Re: (X-Static)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X-Static &raquo;</TD></TR><TR><TD CLASS="quote">yeah i was a lil paranoid on mine too...
ive been running my stock plugs and wires since the swap and its def. time to change them, is it the same principle? b16 is a b16 is a b16?</TD></TR></TABLE>
i'd use ngk plugs for b16. i found that 90-93 integra wires fit better. the wire doesn't matter as long as when you ohm them out resistance is less than 25k ohms.
Old Aug 18, 2004 | 07:30 PM
X-Static's Avatar
Default Re: (eda6 hb)
so NGK's for the 99-00 Si, w/ stock gap?
XYRS2LT
Feb 14, 2011 03:16 PM
DeDonDeRosa
Nov 11, 2008 05:16 PM
91crxturbo
Aug 31, 2006 10:32 AM
92integraVTECgsr
Apr 7, 2006 05:25 PM
703_Sleeper
Feb 12, 2005 06:04 AM
