JDM H22A Autotensioners
Old Aug 18, 2004 | 06:47 PM
MackDad's Avatar
Default JDM H22A Autotensioners
Has anyone had a problem with the JDM Autotensioners, or just the USDM engines?
Old Aug 18, 2004 | 07:11 PM
CBR's Avatar
CBR
Default Re: JDM H22A Autotensioners (MackDad)
Same as the US spec ones. If you have a JDM engine, you should replace the auto-tensioner before installing/running the engine.
Old Aug 18, 2004 | 08:05 PM
Hondaaccordvtec's Avatar
Default Re: JDM H22A Autotensioners (CBR)
I've been running the auto-tensioner on my JDM H for more than 2 yrs now - no problems to speak of yet.
Old Aug 18, 2004 | 08:07 PM
KW2000's Avatar
Default Re: JDM H22A Autotensioners (Hondaaccordvtec)
ive had a friends auto tensioner freeze up once i guess mt tensioners are better u od'nt have to worry about them locking up
Old Aug 19, 2004 | 08:04 AM
satan_srv's Avatar
Default Re: JDM H22A Autotensioners (KW93LUDE)
The auto-tensioner sucks equally across all continents
Old Aug 19, 2004 | 08:11 AM
AndyD's Avatar
I still don't get why Honda engineers had to make the tensioner so complex. Both the manual and auto tensioner. Couldn't that have made something like the brackets used to keep the accessory belts tight??
Oh well.
Old Aug 19, 2004 | 08:23 AM
satan_srv's Avatar
Default Re: JDM H22A Autotensioners (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">I still don't get why Honda engineers had to make the tensioner so complex. Both the manual and auto tensioner. Couldn't that have made something like the brackets used to keep the accessory belts tight??
Oh well.</TD></TR></TABLE>''The whole point was as the belt loosened over time the tensioner would automatically tighten the belt reducing the possibility of belt swap/skipping and problems. Unfortunately it also has to issue of failure, which they didn't expect/
Old Aug 19, 2004 | 05:22 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: JDM H22A Autotensioners (satan_srv)
hey fellas theres a recall on usdm auto tensioners all the way up to 2000. Just take your **** to the dealer and have em swap it. (the seals are bad on them)
Old Aug 19, 2004 | 05:27 PM
Kal's Avatar
Kal
Default Re: JDM H22A Autotensioners (cb7-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R &raquo;</TD></TR><TR><TD CLASS="quote">hey fellas theres a recall on usdm auto tensioners all the way up to 2000. Just take your **** to the dealer and have em swap it. (the seals are bad on them) </TD></TR></TABLE>
and how does this pertain to "JDM H22A Autotensioners?"
Old Aug 19, 2004 | 05:41 PM
BrokeLude's Avatar
Default Re: JDM H22A Autotensioners (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">and how does this pertain to "JDM H22A Autotensioners?"</TD></TR></TABLE>
Easy, with a good USDM tensioner, the original poster doesn't need to look for a JDM tensioner...
Old Aug 19, 2004 | 09:01 PM
Kal's Avatar
Kal
Default Re: JDM H22A Autotensioners (BrokeLude)
it's talking about the problems with the autotensioners, not where to get a "good" one.
Just switch to a manual tensioner, less hassle, less problems
Old Aug 20, 2004 | 01:40 PM
satan_srv's Avatar
it's not a recall.
Old Aug 20, 2004 | 04:18 PM
BrokeLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">it's not a recall.</TD></TR></TABLE>
I couldn't find any recall info either. If they really do have improved auto tensioners, is there some exchange program, do you just have to buy them, or???
Old Aug 21, 2004 | 01:07 PM
iwhichisme's Avatar
no you have to buy them. They come in a kit along with the timing blet. the kit costs $132 and some change.
Old Aug 28, 2004 | 04:44 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
well what do you call it then???
Old Aug 29, 2004 | 02:56 PM
SKDRCR's Avatar
well what do you call it then???</TD></TR></TABLE>
It's probably just a TSB (technical service bulletin)
Old Aug 29, 2004 | 03:16 PM
Daemione's Avatar
Default Re: JDM H22A Autotensioners (SKDRCR)
It's not even a TSB. Just an updated part (that has yet to be proven to be any more reliable than the original).
Propulsion
Nov 10, 2006 01:10 PM
HandoEX
Mar 29, 2006 07:23 PM
need_a_h22
Jan 6, 2006 05:52 AM
abeaujuin
Jul 24, 2004 05:27 AM
