Oil on outside of plugs...
Old Aug 18, 2004 | 06:18 PM
BrokeLude's Avatar
Default Oil on outside of plugs...
I noticed this on a couple plugs when I changed them recently. I'm assuming a lead in the valve cover gasket or something like that, or possibly just some oil that spilled under the cover, as I had a shop change it once when it was cold as hell outside. Internal sides were fine. Anybody know for sure what causes this?
It's an H22A1.
Old Aug 18, 2004 | 06:24 PM
Carbon_Lude98's Avatar
Default Re: Oil on outside of plugs... (BrokeLude)
i had a civic that did that once..
ended up being a leaking head gasket..
hope thats not it...gl man.
Old Aug 18, 2004 | 06:26 PM
117's Avatar
117
Probably the spark plug donuts on the valve cover. I had an older Integra that did that. Replaced those donuts, and the problem went away. The rubber gets hard with age, and eventually starts leaking.
Old Aug 18, 2004 | 08:26 PM
BrokeLude's Avatar
Default Re: (117)
Don't think it's the head gasket because it doesn't seem to burn oil at any noticable rate. If it's leaking past the "donuts", where is it coming from originally?
Old Aug 18, 2004 | 10:35 PM
Speedra500's Avatar
Default Re: (BrokeLude)
from inside the valvecover
Old Aug 19, 2004 | 07:15 AM
BrokeLude's Avatar
Default Re: (Speedra500)
Do I need to change the valve cover gasket or is this just a fact of life with the H22?
Old Aug 19, 2004 | 08:17 AM
Behan's Avatar
Change the valve cover gasket and the spark plug grommets. 99.9% chance that is your problem.
You need # 3 and ( 4 of ) # 4
http://www.slhondaparts.com/br...=true
Old Aug 19, 2004 | 08:46 AM
BrokeLude's Avatar
Default Re: (Behan)
Cool bro, thanks. I've got a timing belt change and valve adjustment coming up when the weather cools off, so I'll add it to the list...
Old Aug 19, 2004 | 11:21 AM
lude_si_95's Avatar
valve cover gasket is a liquid gasket right??
Old Aug 19, 2004 | 11:27 AM
98TypeSH's Avatar
Default Re: (lude_si_95)
its a rubber gasket that you gotta grease up to seal right. You wouldent believe how many problems that little fuggin gasket causes. If you take the valvecover off, 90% chance you have to replace it because its ripped/or not seating right.
Old Aug 19, 2004 | 11:42 AM
lude_si_95's Avatar
Default Re: (98TypeSH)
yeah i bet....i gotta fix mine its leakin around the back corner
Acura_DreamiN
Oct 26, 2010 07:23 PM
HGZ
Feb 18, 2007 11:27 AM
erikiksaz1
13
Oct 7, 2004 06:21 AM
4genaccordfreak
Jan 4, 2004 01:07 PM
rockwilda
Jun 9, 2003 09:52 AM
