Yes. Another buddy club thread. (Skunk2 Stage 2 /JUN 3 owners chime in)
Old Aug 18, 2004 | 06:16 PM
teg92's Avatar
Default Yes. Another buddy club thread. (Skunk2 Stage 2 /JUN 3 owners chime in)
So I can't figure it out for the life of me. Buddy Clubs are the latest and greatest, BUT I still am lost. What cams do I get for my 12.4:1 B20VTEC with a mild "ITR" style port job, AEBS manifold, 4-2-1 tri-y 2.5" header & exhaust... I've currently got B16A automatic cams, so anything would be better right now...
We've all seen the amazing graph of the BC's vs. the CTR's... BC's make amazing low end power. However, there are no graphs of BC's vs. the proven s2s2 cams, or even JUN3's... For a daily driver, I supposed it makes sense to get the BC's for the better low end torque, but what I am wondering is how does the low end/midrange of s2s2's compare to CTR cams? Everyone raves about the low end of the Buddy Clubs.. Is it really THAT much better than say skunk2 stage2s? Do Skunk2 Stage2s actually make less torque & midrange than CTRs?
Old Aug 18, 2004 | 06:30 PM
UncleD's Avatar
Default Re: Yes. Another buddy club thread. (teg92)
skunk 2's have about the same low-mid range power as a type r cam, but they have allot more tope end. You said you have a B20 with a try-y header, so you already have allot of low end power/torque. I guess what I would ask is do you want to improve on that low end torque that you have over a b16, or do ytou want more tope end? I personally wouldn't want to rev a B20 like I would a b16, but thats just me. Where do you want your power to come in at, and die off according to your redline and your life expectantcy of your motor........
Old Aug 18, 2004 | 06:40 PM
teg92's Avatar
Default Re: Yes. Another buddy club thread. (clean rice)
I guess I should mention my bottom end is fully built, no issues there...
Old Aug 19, 2004 | 05:49 AM
teg92's Avatar
Seemed to have found some interesting inconsistancies...
It actually seems the buddy clubs don't make all that much more torque than his motor did with the spec A's... Granted numbers may not be the same since it seems to not be done on the same dyno, but the torque curve on the dyn aut copies seem real fat...
Omniman's B19VTEC w/dynamic autosport spec cams (s2s2 copies)
taken from thread https://honda-tech.com/zerothread?id=595138
Omniman's B19VTEC w/buddy club spec 3+ cams
taken from thread https://honda-tech.com/zerothread?id=894260
Omniman's website, claiming the dynamic autosport dyno is actually using buddy club cams....
http://www.omnipowerusa.com/Dyno/Dyno_3.asp
What I can't figure out is why omnipower website shows his dyno with different cams posted as BC's?
Old Aug 19, 2004 | 06:59 AM
Rollo Lawson's Avatar
the 212whp is the spec3+'s vs. CTR(Red). i could be wrong so don't quote me, but, i remeber it to be that way. why don't you wait for the BC 4's before you decide?
Old Aug 19, 2004 | 10:51 AM
vtec69's Avatar
Default Re: (B16C1)
wow the bc made a good amount of power
Old Aug 19, 2004 | 12:47 PM
_unknown_'s Avatar
I believe the 1st dyno chart was at Dynamic (which typically reads high) and the other was at Trackmasters??? (which reads low)...
Old Aug 19, 2004 | 06:03 PM
rodimus's Avatar
Default Re: Yes. Another buddy club thread. (garth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garth &raquo;</TD></TR><TR><TD CLASS="quote">I believe the 1st dyno chart was at Dynamic (which typically reads high) and the other was at Trackmasters??? (which reads low)...</TD></TR></TABLE>
almost correct.
because of the elevation at the trackmasters dyno (back when it was open) the numbers read notoriously lower versus other similar dynos which are closer to sea level.
the dynamic autosports dyno doesn't read all too high compared to other dynojets (from what i've seen)
Forrest Gump 9
Mar 27, 2006 12:42 PM
lopaka07
17
Jul 23, 2005 12:33 AM
sushibug
Aug 18, 2002 07:41 AM
spankaveli
Feb 13, 2002 04:16 PM
HX_Guy
Dec 23, 2001 06:19 PM
