Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Start up after prolonged storage?
Old Aug 18, 2004 | 05:38 PM
bulldog_RS20's Avatar
Default Start up after prolonged storage?
Any tips?
My pig has been idle for a few months with a bad case of the wrinkles...(wreck damage).
Should I dump a little oil in each cylinder before start up to pre-lube the engine? Will this foul the plugs?
TIA
Greg
Old Aug 18, 2004 | 05:41 PM
Dan GSR's Avatar
Default Re: Start up after prolonged storage? (bulldog_RS20)
take out the spark plugs, and crank the engine over several times to prime the oil system
Old Aug 18, 2004 | 05:47 PM
jisu009's Avatar
Default Re: Start up after prolonged storage? (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">take out the spark plugs, and crank the engine over several times to prime the oil system</TD></TR></TABLE>
Yeah, just to be on the safe side....But a couple of months ain't too long. You should try and start it every couple of weeks and let it run for a minute or two.....That or just go race the bitch!
Old Aug 18, 2004 | 06:19 PM
.RJ's Avatar
.RJ
Default Re: Start up after prolonged storage? (jisu009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">You should try and start it every couple of weeks and let it run for a minute or two.....</TD></TR></TABLE>
Thats the worst thing to do.
It will collect moisture in the crankcase and exhaust system that does not get burned off and waste battery charge. Let it sit if you're not going to warm it all the way up.
Old Aug 18, 2004 | 06:20 PM
jisu009's Avatar
Default Re: Start up after prolonged storage? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Let it sit if you're not going to warm it all the way up.</TD></TR></TABLE>
That is what I ment to say...Bring it up to temp.
Old Aug 18, 2004 | 11:35 PM
LSpimpTEC's Avatar
unplug the ecu and crank to get oil into the system. then start and warm up
Global688
Nov 27, 2007 05:27 AM
g2tegsown
May 10, 2007 05:05 AM
Initial DA6
Feb 9, 2006 08:01 PM
Flux
Apr 23, 2005 08:25 PM
fastludeh22
Jun 3, 2003 03:45 PM
