help...i have a wiring question
Old Aug 18, 2004 | 05:35 PM
bustah49's Avatar
Default help...i have a wiring question
i have a 91 civic dx...i want to convert the car to mpfi. i just picked up a rolled 89 crx si. here is the question....will all of the wiring from the crx work in my 91 civic? i mean if i rewire the whole car? from headlights to tail lights. or is there an easier way?
Old Aug 18, 2004 | 05:39 PM
T--Rex's Avatar
Default Re: help...i have a wiring question (bustah49)
are asking if there is a easier way to do a mpfi conversion than to swap all of the wires in the entire car?
Old Aug 18, 2004 | 05:40 PM
bustah49's Avatar
Default Re: help...i have a wiring question (Matrix_Zero)
i am asking if i can swap all of the wires? or do i have to use the entire dash and all?
Old Aug 18, 2004 | 05:42 PM
vtecn8ive's Avatar
If you search you will find your answer. But in the long run it will be a lot easier if you just swap certian parts around and the DPFI will be a MPFI. Also I believe wiring of the dash is different. 88-89 CRX(not positive on Civics) dash wiring is different from 90-91 CRX's. Different rear tails. Alot of different things. Why would you convert the entire wiring just to have MPFI???
Old Aug 18, 2004 | 05:48 PM
bustah49's Avatar
Default Re: help...i have a wiring question (vtecn8ive)
i wanted to put the si motor in the civic also...with the 5 spd. my car only has a 4spd now. so you say i should just do the dpfi-mpfi swap?
Old Aug 18, 2004 | 05:53 PM
vtecn8ive's Avatar
^ Yup. Just convert the DPFI to MPFI. No need to mess around with every single strand.
This should help you out. http://fourthgenhatch.com/mpfi.html
Old Aug 18, 2004 | 07:47 PM
Rywire's Avatar
Thats a great site listed above, but if its too much, I can do it for ya. Click the bottom link in my sig.
Ryan
Old Aug 19, 2004 | 06:22 AM
bustah49's Avatar
Default Re: help...i have a wiring question (droppedcrxsi)
thanx guys...you all kick ***. this is for my sons 91 civic. i am planning on boosting it. it has my 97 d16y7 motor in it now...with a 95 civic ex head.
would you guys use the setup that i have now? or would you use the setup from the crx si?
Old Aug 19, 2004 | 07:23 AM
Uncivilized's Avatar
I've done both ways, I find it easier to remove the dash and change the whole harness, you only need to change it to the driver side kick pannel(Across the firewall, and out the the engine bay on both sides). Plus it looks a whole lot better, and more stock, plus less problems afterwords. Just make sure you have a common year, they are different.(88-89 & 90-91)
Old Aug 19, 2004 | 07:45 AM
vtecn8ive's Avatar
Default Re: help...i have a wiring question (Uncivilized)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Thats a great site listed above, but if its too much, I can do it for ya. Click the bottom link in my sig.
Ryan</TD></TR></TABLE>
Great site to check out.
csoares
Audio / Security / Video
Oct 8, 2012 09:55 AM
Quik S2K
Classic Hondas
Nov 18, 2007 04:34 PM
