A/C Problems
Old Aug 18, 2004 | 04:58 PM
mikeyg's Avatar
Default A/C Problems
I finally got my compressor and installed it and charged up the system. For some reason it is not getting cold enough. It was 100 degrees outside and the vent temp was 75 degrees. I think its supposed to be at least 35 degrees colder than the outside temp. It seems like the drivers side vents are a little colder than the passenger vents. I checked the pressure in the system and it is 45 psi. Does anyone have any ideas?
Old Aug 18, 2004 | 05:01 PM
IronOutlawz's Avatar
Default Re: A/C Problems (mikeyg)
did you fill it up yourself or did you have a shop do it? If you paid someone to do it I would take it back and make that fix it because it sounds like there's air in your system still.
Old Aug 18, 2004 | 05:07 PM
mikeyg's Avatar
Default Re: A/C Problems (IronOutlawz)
I did it. You think there is that much air in the system? I used those cans that have the oil and freon in the same can. They had 11oz freon and 2oz of oil and I used 2 cans.
chikin pickle
Apr 28, 2013 06:45 AM
ndiehm
Apr 30, 2012 10:30 AM
Mackln308
Honda Civic (2001 - 2005)
Oct 8, 2009 08:32 PM
97akwerd
Sep 14, 2005 08:06 PM
