new engine on my ef (questions)
Old Aug 18, 2004 | 04:30 PM
spoon*honda
Guest
Posts: n/a
Default new engine on my ef (questions)
hey I want to upgrade the engine on my 1989 Lx sedan, Im gonna be buying a 1993 si swap for now, what modifications will I need to do inorder to make the swap,its it hard to do?please help me out here
Modified by spoon*honda at 2:50 AM 8/19/2004
Old Aug 18, 2004 | 04:50 PM
Mattamotor's Avatar
Default Re: new engine on my ef (spoon*honda)
why are buying a CX swap? You will lose 22 horsepower(92hp to 70hp) and get a very long geared tranny in the process. If you going to get anything get a D series 1.6. Sohc vtec, sohc, or dohc take you pic.
Old Aug 18, 2004 | 05:00 PM
spoon*honda
Guest
Posts: n/a
Default Re: new engine on my ef (Mattamotor)
sorry I meant a sohc Vtec fron a 93 si
Old Aug 18, 2004 | 05:25 PM
Superhatch's Avatar
Try the search feature... *opens new window and does search for you*
Searched EF fourm only "vtec"
https://honda-tech.com/zerothread?id=889009
https://honda-tech.com/zerothread?id=708058 <--good post
https://honda-tech.com/zerothread?id=454573
Use the search first next time
Edit: many more there...just choose those 3
Old Aug 18, 2004 | 05:31 PM
Mattamotor's Avatar
mechanics wise it is very easy swap. wiring wise to run the stock ECU you will need to convert to MPGFI and wire in the OBD 1 stuff. You will also need a Throttle cable for a SI/EX EF , and various vacuam lines thats can probably be reused from thr old engine. If you go with the 92-95 ecu you will need to get a eletronic speed sensor so that you vtec will work.
Basically the wiring going to be pain in the ***. I also hate wiring though.
Old Aug 18, 2004 | 05:52 PM
spoon*honda
Guest
Posts: n/a
thanks, will I need this >>>> http://cgi.ebay.com/ebaymotors...=WDVW if so what else will I need?
Modified by spoon*honda at 7:49 PM 8/19/2004
Old Aug 19, 2004 | 06:43 PM
spoon*honda
Guest
Posts: n/a
ttt
Old Aug 19, 2004 | 06:56 PM
Fleas_Ef's Avatar
i would say get a zc bolts right up, then turbo that peice sohc vtec would be nice to but that needs a turbo too
Old Aug 19, 2004 | 09:14 PM
spoon*honda
Guest
Posts: n/a
Default Re: new engine on my ef (Fleas_EF)
any link of a ZC?will this fit http://cgi.ebay.com/ebaymotors...33615 or this http://cgi.ebay.com/ebaymotors...=6755 or maybe this http://cgi.ebay.com/ebaymotors...33615
ef8ftw
Mar 17, 2010 02:29 PM
solfly
Jun 4, 2008 06:24 AM
SL0-hatch
Apr 29, 2008 01:48 PM
91siguy
Feb 24, 2007 01:32 AM
87hondacivic
Apr 1, 2004 05:38 PM
