how to take off door molding without tearing anything up?
Old Aug 18, 2004 | 04:09 PM
91hondacrx's Avatar
Default how to take off door molding without tearing anything up?
how do i do this??
Old Aug 18, 2004 | 05:36 PM
Patch's Avatar
Default Re: how to take off door molding without tearing anything up? (91hondacrx)
Take all the screws out of it, take the clip off of the window handle and take it off. Then just pop the panel off, voila.
Old Aug 18, 2004 | 09:33 PM
91hondacrx's Avatar
Default Re: how to take off door molding without tearing anything up? (Patch)
Im not talking about the door panel, im talking about the outside molding, like in the middle of the door that runs from left to right. Because once you pop off the door panel, then there is a piece of frame that is right behind the door molding on the inner side of the door. Any help would be appreciated.
Thanks,
Matt
Old Aug 18, 2004 | 09:39 PM
s2k_al's Avatar
Why are u taking off the molding. Are you selling it? Let me know if you are.
Old Aug 18, 2004 | 10:16 PM
kurinto's Avatar
Default Re: (c_rex88)
On the inside of the door near the latch side there should be a 10mm nut that holds the trim on. Take that off then slide the trim towards the front of the car, you may need to take the trim off the fender in front of it to make room. I think thats how you it, I may be confusing it with the other trim piece on the door.
Old Aug 18, 2004 | 10:46 PM
Riceburner247's Avatar
Default Re: (kurinto)
If you're not gonna use it again, just take the 10mm nut off as stated in the previous post, then pull outward while a friend busts the plastic clips off with a screwdriver. Make sure your friend knows what he's doing.
Old Aug 18, 2004 | 11:22 PM
Gumbey75's Avatar
take the screw out on each side then procead to rip away.... u can always get the clips from the junkyard like i did!!
Old Aug 19, 2004 | 06:53 AM
91hondacrx's Avatar
Default Re: how to take off door molding without tearing anything up? (Gumbey75)
well i have another car (parts car)that has them on there, and they are painted the same color as my car. If i could swap them without messing anything up then i think it would look better. So i dont want to tear anything up. IF anyone is looking for some side molding i think i have some extra in the gayrage. Let me know and throw me an offer.
Thanks,
Matt
grape1161
14
Mar 30, 2010 12:28 AM
suhteevin
Jan 6, 2009 09:04 PM
integracura
Dec 17, 2007 02:06 PM
bonestock91
Aug 12, 2006 01:12 AM
snake01
Jan 11, 2002 09:06 PM
