modified B16 CA smog questions, will it pass emissions?
Old Aug 18, 2004 | 03:17 PM
Reelizmpro's Avatar
Default modified B16 CA smog questions, will it pass emissions?
If I install a cat on my B16'd CRX will it pass CA emissions? I'm not worried about the visual, just the emissions. Here are the mods
CTR cams
B&M AFPR
high flow fuel pump
DC headers
Iceman intake
test pipe (for now)
trust exhaust
Mugen chipped B16 ECU
Old Aug 18, 2004 | 03:19 PM
EL Vap133's Avatar
Default Re: modified B16 CA smog questions, will it pass emissions? (Reelizmpro)
Try it and find out.
Old Aug 18, 2004 | 03:24 PM
Wes V's Avatar
Default Re: modified B16 CA smog questions, will it pass emissions? (EL Vap133)
Go to a smog station and ask them to run a "partial" test. Make it clear that you are interested in how it runs and DON'T want a full test that would be logged on the DMV system.
It's a reasonable request and is what I did prior to going to the Referee. That way you can find out if you have a problem before it becomes an issue.
There is nothing sleazy or illegal about this!
Wes
Old Aug 18, 2004 | 04:18 PM
91civicEX's Avatar
only problem i see is the mugen chip and the cams. cams are stock so they should be close but changing the chip or ecu will make ur car run cleaner
gurlugotmilk
Sep 4, 2007 04:38 PM
Codename47
Nov 5, 2004 12:14 PM
neoburi
May 10, 2003 10:33 AM
silvershiny-ek
May 8, 2003 07:29 PM
dimsum
Mar 14, 2002 02:28 PM
