Putting Si or ITR calipers on a dx hub? (EK)
Can I fit these bigger calipers on the 96 dx if I buy the corresponding rotors?
I was thinking of getting the Si front hub assembly, but if I can simply buy the calipers and rotors and fit them on my existing dx hub, it would save a lot of work.
Is this possible?
Is this possible?
the brakets on the ex/si are larger so yes you would need the front knuckle off either one (ex or si...or integra). If you want to use your stock dx setup you will need to make some brackets.
There is a thread out there w/ itr brake info...look for it because I really dont want to explain that one (because I cant remember exactly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">the brakets on the ex/si are larger so yes you would need the front knuckle off either one (ex or si...or integra). If you want to use your stock dx setup you will need to make some brackets.
There is a thread out there w/ itr brake info...look for it because I really dont want to explain that one (because I cant remember exactly)</TD></TR></TABLE>
are you referring to the 92-95 si's or the 99-00 si's? i'm looking to put itr caliper brackets (with 2 pot legend calipers) on my 92 si, but i would also like to keep my stock hub setup. do you know if this is possible?
zerovandez
May 10, 2012 06:03 AM
Redline96LX
37
Feb 20, 2012 02:53 PM
crooked muffler
Jan 16, 2003 08:04 AM
