Help me identify weird problem: Car randomly dies while driving or on startups
Old Aug 18, 2004 | 01:55 PM
Propulsion's Avatar
Default Help me identify weird problem: Car randomly dies while driving or on startups
89 civic dx
b17a
obd0 pr3 ecu
Symptoms: (seems to be getting worse)
-everything ran fine for a few months, just replaced the fuel pump
-randomly dies while driving. rpm just drops to zero.
-when trying to start the car again, it usually takes a few tries, car would fire up, then die again instantly.
Observations:
-when I turn the key 2 clicks, usually all the little indicators lights light up for a couple seconds, and I can hear the fuel pump prime. However when car was exhibiting symptoms last night, this didn't happen.
I would turn the key 2 clicks, and everything's still dark (no fuel pump priming). Only when I turned it a bit more(between 2 clicks and ignition), the lights would light up.
I was able to fire up the car, and maintain the engine running while holding the key at this position, but as soon as I let it return to the 2-click position, car dies instantly.
I am stumped, I have some guesses, but I'd like to hear opinions first. Thanks
Modified by SilverCIVIC96 at 6:30 PM 8/18/2004
Old Aug 18, 2004 | 02:59 PM
Propulsion's Avatar
Default Re: Help me identify weird problem: Car randomly dies while driving or on startups (SilverCIVIC96)
going to try to resolder the main relay, think this will work?
Old Aug 18, 2004 | 03:22 PM
cbstd's Avatar
Sounds like your ignition switch is bad. It happens. Specially if someone had a lot of keys on their key ring.
Old Aug 18, 2004 | 03:26 PM
ceLtic's Avatar
N/A wh0re!
Default Re: Help me identify weird problem: Car randomly dies while driving or on startups (cbstd)
is your battery connection/alternator connection loose?
Old Aug 18, 2004 | 04:05 PM
DieMaster's Avatar
Needs to be About 20% Cooler
i had that exact same problem in my 89 LX and it was the ingnition swich.
Old Aug 18, 2004 | 05:31 PM
Propulsion's Avatar
Default Re: Help me identify weird problem: Car randomly dies while driving or on startups (JC18)
yeah, I just searched for ignition switch, and people are describing this exact problem - driving w/ one hand holding the key... lol
I think Ill get a new one from the dealer and give it a shot. If anyone else have suggestions, plz contribute.
Old Aug 18, 2004 | 05:58 PM
b1r469's Avatar
another option would be to find the wire the switch turns on and cut it and hook it to a physical switch. Just make sure it is rated for the correct amperage.
on a side note. This is a good idea if you want to hide the switch. Makes the car difficult to steal if they cannot start it.
Old Aug 18, 2004 | 06:59 PM
Propulsion's Avatar
Default Re: (b1r469)
hmm, interesting idea
Old Aug 20, 2004 | 11:07 AM
Propulsion's Avatar
Default Re: (SilverCIVIC96)
it was the ignition switch, got a new one at the dealer, and problems is fixed...
Thanks guys, HT comes through again
joe.s
Honda Civic (2001 - 2005)
Jun 23, 2018 10:04 AM
d1nki
Aug 25, 2016 09:37 AM
MallyG44
Acura TSX
Aug 2, 2015 04:02 PM
yeaaaa its slow
Mar 6, 2006 07:20 AM
