Will a S2000 exhaust fit a RSX type S ???
well, the S2000 exhaust system is a dual exhaust system. the rsx exhaust system is single. do you really think its gonna just bolt in? it could work if you wanted it to. you'd have to weld brackets to the unibody in the right places. get your hangers and everything situated. the exhaust would probably hang really low, so it would scrape on just about every speed bump and large pothole, among other obstacles in the road. i don't think you'd get many gains out of it, and there isn't a notch in the bottom of the rear bumper on both sides for the exhaust tip, so for it to look halfway decent, the bumper would have to be cut on the driver's side to make room for the tip to be level with the tip on the passenger's side. and if you cut the bumper, it actually would not look very decent most likely.
if you're not after performance, but you just want a different/neat look for your rsx, and you want it to look professional and sorta stock, it probably wouldn't be such a bad idea. i think it could be pulled off and still look good.
omg_miiiike
Mid-Atlantic (Sales)
Jan 6, 2008 08:20 PM
OC 335i
Nov 19, 2007 10:32 PM
