CLUTCH HAS NO PRESSURE
I HAVE A PROBLEM WITH MY ACCORD. WHEN I STEP ON THE CLUTCH, IT GOES STRAIGHT DOWN AND DOESN'T COME BACK UP. I'VE TRIED BLEEDING IT OVER AND OVER AGAIN BUT STILL NO RESULTS. IS THERE ANYONE WHO HAS A SOLUTION TO THIS PROBLEM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H »</TD></TR><TR><TD CLASS="quote">you either have a bad master cylinder, slave cylinder, or broken pressure plate if the bleeding hasn't helped...</TD></TR></TABLE>
Or it's not getting bled good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDADRAGONSTAR »</TD></TR><TR><TD CLASS="quote">I HAVE A PROBLEM WITH MY ACCORD. WHEN I STEP ON THE CLUTCH, IT GOES STRAIGHT DOWN AND DOESN'T COME BACK UP. I'VE TRIED BLEEDING IT OVER AND OVER AGAIN BUT STILL NO RESULTS. IS THERE ANYONE WHO HAS A SOLUTION TO THIS PROBLEM?
did you replace any parts yet? Once, I bought a faulty master cylinder, and I had to replace the new cylinder. Sometimes, "new" products could be faulty.
I would say your pressure plate is screwed, but it could be anything that Nick mentioned.
