Wheel clearance...not enough?
Old Aug 18, 2004 | 08:32 AM
ItalynStylion's Avatar
Default Wheel clearance...not enough?
I have a 98 prelude base model. I just bought some motegi MR7's and BFGoodrich Gforce TA KDW's. The rims are 17x7. I might be having some rubbing issues with the inner fender wells. When i go over a bump and the car sits down a little i can hear it. The tires show no signs of wear and neither do the fender wells. My car isnt lowered, should my rims fit alright?
Old Aug 18, 2004 | 08:43 AM
Behan's Avatar
Default Re: Wheel clearance...not enough? (ItalynStylion)
yes the rims should fit without rubbing. You may have worn shocks, if you are rubbing when you hit a bump that is usually a good indication that your shocks need replaced.
Go out to your car, put some weight over the tires ( i.e. push them down ) and see how they rebound. The car shouldn't bounce, it should come back with a slight bbit of settling.
Old Aug 18, 2004 | 08:46 AM
Default Re: Wheel clearance...not enough? (Behan)
It doesnt bounce. I heard something about a "bushing" in the rear shocks that sometimes make a clunking noise, think that could be it?
mrfrecks65
Apr 8, 2017 06:02 PM
Low3Piru
Jan 27, 2008 11:35 PM
jdmteg96
May 25, 2004 02:27 PM
92JDMSiR
Jul 23, 2003 06:06 PM
paulyman
Mar 19, 2002 02:11 PM
