code 16
Old Aug 18, 2004 | 07:22 AM
1.5 liter's Avatar
Default code 16
my idle keeps drowing on me. the idle boggles between 1000 and 0 rpms. sometimes i have to push the gas pedal to keep the car from turning off. i know code 16 is the injectors but what can i do to fix this problem.
please help!!!!!
Old Aug 18, 2004 | 07:53 AM
tgreaves's Avatar
Default Re: code 16 (1.5 liter)
Might be that your eacv has gone bad.. Is this a dx? Is it a civic or crx?
Old Aug 18, 2004 | 08:06 AM
DieMaster's Avatar
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.5 liter &raquo;</TD></TR><TR><TD CLASS="quote"> i know code 16 is the injectors but what can i do to fix this problem.</TD></TR></TABLE>
Is that the only code it's giving you? could be you have bad / dirty injecters. i recomend using a Though-gas-tank cleaner at least every 500 Mi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Might be that your eacv has gone bad.. Is this a dx? Is it a civic or crx?</TD></TR></TABLE>
I agree what kinda car is it? DPFI or MPFI? and what does a EACV have to do with a code 16?
Old Aug 18, 2004 | 08:10 AM
tgreaves's Avatar
Default Re: code 16 (JC18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JC18 &raquo;</TD></TR><TR><TD CLASS="quote">
Its an obd0 car.. If the car doesnt start for any reason it will throw a code 16(fuel injector).. When I was obd0 on my crx I threw a code 16 when my fuel pump died.. If you pull the plug wires off and try to start it you will get a code 16.. Crazy huh..
Old Aug 18, 2004 | 11:06 AM
1.5 liter's Avatar
Default Re: code 16 (tgreaves)
its a civic and a dx
bgcrx
Feb 21, 2008 07:24 PM
innes887
May 1, 2007 03:33 AM
sitrucjr
May 22, 2004 10:47 PM
SLIMJIMsi97
May 2, 2003 11:06 PM
