Anyone using a S2000 muffler?
Old Aug 18, 2004 | 06:38 AM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Anyone using s2000 muffler setup on their cars?
I currently have my bottlenecks removed from the stocl catback w/ smsp testpipe. I have a chance to buy a s2000 muffler (looks like mugen twin loop) and thinking of installing it. Has anyone used this muffler before? If so can you give us a review.
Old Aug 18, 2004 | 10:52 AM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: Anyone using s2000 muffler setup on their cars? (MUTANT X)
S2k muffler on an ITR? does it fit? i thought the s2k's a dualie? So you're planning to use a single one on the ITR? Well, just have some dyno charts up after you do it.
Old Aug 18, 2004 | 11:12 AM
ZygSpeed's Avatar
Ummm ... WHY?
Get ready to do some fabrication.
Old Aug 18, 2004 | 01:43 PM
Cosworth's Avatar
Default Re: Anyone using s2000 muffler setup on their cars? (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Ummm ... WHY?
Get ready to do some fabrication.</TD></TR></TABLE>
exactly my sentiment. ITR muffler flows good enough for most applications. The $ you spend to make a S2K muffler fit an ITR, you could probably just buy yourself a pre-fabbed RM-01a.
Old Aug 18, 2004 | 02:04 PM
RTW DC2R's Avatar
Default Re: Anyone using s2000 muffler setup on their cars? (Cosworth)
unless you can do this sort of work yourself
typically they say the ITR muff flows "40% better" than a GSR muff, any one hear any stats on the S2K muff compared to ITR muff? Not that I even have a car to try this on anyway lol
one more time, muff.
Old Aug 18, 2004 | 02:10 PM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Ummm ... WHY?</TD></TR></TABLE>
Old Aug 18, 2004 | 02:17 PM
Bradstard's Avatar
I remember seeing a blue EG in the appearance forum that had one on it...
Old Aug 18, 2004 | 05:03 PM
an2ny888's Avatar
did removing the bottlenecks do any good? or did they just make the car louder?
Old Aug 18, 2004 | 06:12 PM
B2FiNiTY's Avatar
You won't really get any gains. The inlet on the muffler is around 2"
Old Aug 18, 2004 | 06:24 PM
Justin Klemgold's Avatar
Default Re: Anyone using s2000 muffler setup on their cars? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">You won't really get any gains. The inlet on the muffler is around 2"</TD></TR></TABLE>
Right on...which means you'll be right back to bottlenecking it....
Why would one consider it? Because it's a twin pass? It's no Hytech...not even close...This twin pass is just to keep the sound down and nothing else...
When you are thinking of doing something like this, one should look at the measurements and diameters...if you would have done this, you would have figured out that it's a no go unless you want to be right back to square one.
Old Aug 18, 2004 | 06:28 PM
B2FiNiTY's Avatar
Default Re: Anyone using s2000 muffler setup on their cars? (Justin Klemgold)
The only reason I would run one is to be different.
Old Aug 18, 2004 | 10:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">The only reason I would run one is to be different. </TD></TR></TABLE>
Different and slower....makes sense I guess...
Old Aug 19, 2004 | 04:55 AM
CALM_AS_A_BOMB
Guest
Posts: n/a
OK see i did not know that the s2k muffler only had a 2" inlet . I just figured it would be better flowing so take it easy on me geeez that's why I ask the initial question because i did not know.
And toi answer the guy who asked about the exhaust decibles by removing bottlenecks ,the answer is yes it did make it a tad bit louder.With the combination of the SMSP test pipe and removal of bottlenecks alone with JDM 4-1 header the R sound is almost comparable to a stock INFINITY G35 coupe.
Old Aug 19, 2004 | 08:39 AM
crafty's Avatar
I was selling one a while back and took measurements....
Inlet
Outlet
strangeyelp
Nov 13, 2008 11:31 AM
BERT-O
Apr 20, 2006 05:33 AM
95excoupe
13
Jan 7, 2005 01:46 PM
truelaostha
Mar 22, 2004 10:40 AM
EF'n
Honda S2000
Mar 26, 2002 10:03 PM
