Can't get gauge cluster apart to install indiglo gauges!, Help!
We took the gauge cluster out, took the clear plastic off, and I think we have to take off the black plastic bezel thing. But when we push in the tabs and try to pry it off, it seems like the thing is stuck on in the middle... We can get it pried open, but it won't pull off all the way and seems like its stuck on there pretty good. Any help would be appreciated. Thanks
Oh yea, and don't tell me to look at team-integra.net, because I already did and the stupid site wouldn't load up.
can you clarify that again please? you said you were able to take out the gauge cluster and the clear plastic out.. but what you can't take the black bezel out? is this right?
what i dont get is..in order to take out the gauge cluster OR the clear plastic piece..you'd have to take out the black bezel out FIRST.
in any case... if you are talking about the black bezel...there are two screws on top of the bezel...unscrew that and pull the bezel down..which should give you some room to squeeze your fingers in...place your fingers so that they are in the 9 and 3 o'clock positions and just towards you
You probably forgot to unscrew the three screws located behind the gauge cluster. You know, the thin green plastic thing that covers the whole back side of it..there are three screws in the left, middle, and right in the center.
I was trying to pry it open without realizing I overlooked those 3 stealthy screws.....lol!
After about 10 minutes of frustration and madness, I realized.
som3on3_10
Jun 10, 2004 05:36 PM
