How much to Replace Transmission and Clutch on a 2001 Type R?
Old Aug 18, 2004 | 01:57 AM
ITR0952's Avatar
Default How much to Replace Transmission and Clutch on a 2001 Type R?
Parts plus labor, I know it's not going to be accurate, but I just want a estimate.
How many miles will they need to be replaced? I drive mad...
Old Aug 18, 2004 | 02:57 AM
ebelp's Avatar
Default Re: How much to Replace Transmission and Clutch on a 2001 Type R? (ITR0952)
Don't drive mad. Drive happy.
It all depends on where you go. If you go to Acura, be prepared to spend close to $3k at least on parts and labor.
Old Aug 18, 2004 | 05:01 AM
Philly_NBP_R's Avatar
Default Re: How much to Replace Transmission and Clutch on a 2001 Type R? (ebelp)
seriously, take it easy on the tranny and clutch, and they will last 150K miles or more...
(I have 86K on mine, and climbing )
worry about replacing it AFTER you break it
Old Aug 18, 2004 | 05:55 AM
b19coupe's Avatar
About $1100 parts and labor at the local dealership. For just the clutch. Why do you think you need a transmission?
Old Aug 18, 2004 | 06:27 AM
Paulnsx's Avatar
i highly doubt you would ever need to replace the tranny from normal wear and tear. you usually only need to replace that if something really odd happens. honda manual trannys are rock solid.
i would think you could get your clutch replaced along with master/slave cylinders for around 1k from a dealer. it would probably cost around 600-800 from a private tranny shop. i think my clutch job on my prelude cost me 750 and i kinda got f'ed over.
i've gotten 197k on a single clutch
Old Aug 18, 2004 | 06:37 AM
Jon D's Avatar
I got a used tranny for sale........i can save you some $$$$
Old Aug 18, 2004 | 07:01 AM
1GreyTeg's Avatar
Default Re: How much to Replace Transmission and Clutch on a 2001 Type R? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Why do you think you need a transmission?</TD></TR></TABLE>
Probably for all his mad burnouts:
https://honda-tech.com/zerothread?id=962815
Old Aug 18, 2004 | 07:15 AM
speedymon's Avatar
Default Re: How much to Replace Transmission and Clutch on a 2001 Type R? (1GreyTeg)
Wow i'm glad i know how to do it myself.
Old Aug 18, 2004 | 07:17 AM
speedymon's Avatar
Default Re: How much to Replace Transmission and Clutch on a 2001 Type R? (speedymon)
Old Aug 18, 2004 | 10:39 AM
RiCE On IcE 2's Avatar
lol how many miles are on ur car anyway? i jsut got my tranny replace some how my 5th gear synchro went bad as did my LSD extended warranty covered a rebuild of my tranny though woohoo.
Old Aug 19, 2004 | 10:20 PM
Mike K's Avatar
Default Re: How much to Replace Transmission and Clutch on a 2001 Type R? (Paulnsx)
if you supplied me with the clutch and transmission, i'd get 'er done for $125 and you'd be on your way in 2 hours or so.
as for prices, i remember in 2002, when i worked for acura i sold transmissions for $1750. and clutch kit for $240.
do the math.
condor22
Jan 1, 2015 08:03 PM
pineapplemike
Sep 27, 2008 09:12 PM
Rob Dizzle
Apr 8, 2004 05:52 AM
b18cya
May 19, 2003 06:05 PM
bgruver
May 21, 2002 11:12 AM
