OBX R cams in GSR?
Has anybody used the OBX cams in their GSR's or b18c swapped civics? I have a95 GSR and want to buy the obx cams because there cheaper than toda, spoon, oem honda, skunk2 and the others. they come in 3 stages, i want to do a type r valve train setup so stage 1 or stage 2?
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
don't do it. you **** with the internals of your engine with cheap *** **** like those, and you get what you pay for.
if you can't lay down the $300-400 for at the very least '00 ITR cams, then you shouldn't be changing your cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dLo GS-RaArRrRrRRRR »</TD></TR><TR><TD CLASS="quote">
if you can't lay down the $300-400 for at the very least '00 ITR cams, then you shouldn't be changing your cams.</TD></TR></TABLE>
00-01 itr cams and ctr oem cams are relatively cheap and a great value...cams are something its worth the extra money you spend on them
compwc18
May 22, 2005 05:05 PM
