New Suspension + Alignment = ???'s
Old Aug 17, 2004 | 09:53 PM
chuckus's Avatar
Default New Suspension + Alignment = ???'s
I'm installing a new set of koni yellows and h&r sports this week. I wanted to know if any alignment shop could align a lowered car?
Also, would the stock/oem specs that the alignment machine has be good enough for a daily driver or is it possible for me to request certain specs?
thanks
:carlos:
Old Aug 17, 2004 | 09:56 PM
Downey's Avatar
Default Re: New Suspension + Alignment = ???'s (chuckus)
if you dont have any adjustable camber kits, the only thing your gonna be able to adjust is toe. any alignment shop can do it. dont let them get you on this "performance alighnment" or "lowered car alignment" for $100+
just get them to set your toe back to factory specs. personaly, i would run 1/16th toe out in front and exactly 0 out back
Old Aug 18, 2004 | 09:16 AM
chuckus's Avatar
Default Re: New Suspension + Alignment = ???'s (Downey)
thanks for the warning...anyone else wanna chime in?
thanks
:carlos:
Old Aug 18, 2004 | 10:05 AM
Chris N's Avatar
Really not much else to say.....
Old Aug 18, 2004 | 10:41 AM
cxSHOE's Avatar
Default Re: New Suspension + Alignment = ???'s (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">Really not much else to say.....</TD></TR></TABLE>
ditto. see what happens after the adjustment readings and go from there.
Old Aug 18, 2004 | 11:14 AM
ZygSpeed's Avatar
Default Re: New Suspension + Alignment = ???'s (cxSHOE)
Depends on how much it's "lowered", and whether they can get it on the alignment rack w/o rubbing the lip, etc.
Old Aug 18, 2004 | 11:28 AM
quick6's Avatar
Toe _out_ in the front?
Doesn't that make the car darty on the highway?
Seems like you'd want to run just a little toe in on the fronts unless you want a hardcore setup for autox or road course... ?
Old Aug 18, 2004 | 01:25 PM
Cosworth's Avatar
Default Re: (quick6)
set front toe to ZERO (same with the rear), if you're mostly going to drive it on the street.
on a fwd, you don't neeed to set the front toe in to drive straight. (rwd would be a different issue as the weight transfer & the way you put down the power is different.)
Old Aug 18, 2004 | 08:27 PM
chuckus's Avatar
Default Re: (Cosworth)
thanks for all the replies...
from what I gathered, stock specs for a daily street driver will be just fine
thanks
:carlos:
Old Aug 18, 2004 | 09:30 PM
mingbling's Avatar
firestone lifetime alignment is the shiznitz.
Old Aug 18, 2004 | 10:20 PM
quick6's Avatar
Default Re: New Suspension + Alignment = ???'s (mingbling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling &raquo;</TD></TR><TR><TD CLASS="quote">firestone lifetime alignment is the shiznitz. </TD></TR></TABLE>
Not if you have modified suspension or exacting alignment specs on a fully adjustable suspension (from what I've heard).
You get what you pay for.
Btw, thanks for the data, Sean.
23LX23
Suspension & Brakes
29
Jul 29, 2010 05:12 AM
CreaseKeeper28
Suspension & Brakes
12
Jul 20, 2009 12:00 PM
soclean1k_JDM
Suspension & Brakes
Jun 30, 2009 05:26 AM
riceforlife
Suspension & Brakes
Dec 27, 2007 04:54 PM
