Hood locks?
http://www.jcwhitney.com/product.jht...D=4706&BQ=jcw2
Does anyone have experience with these?
Thanks
Thanks
All hood pins/locks require you to drill into the hood, unless there is some side-clamping mechanism that I'm not aware of.
If you have a stock hood, then forget them. That is unless you are competeing then they are required.
you are looking for the other type of hood lock. Use either the cable type or the electronically activated solenoid type. http://WWW.autotoys.com has both, JC has the cable type.
i know a couple of fellas that have the barrel locks on the hood...not sure where they got em but they said they were a bitch to get em to line up properly so they can lock...they said it was a 10X worse then installing regular hood pins..
lblingldawg
10
Apr 21, 2006 07:27 AM
brasilracing
Aug 5, 2004 04:51 PM
