94 Civic DX...need correct order for spark plug wire connections to distributor?????
Old Aug 17, 2004 | 06:33 PM
cnh4's Avatar
Default 94 Civic DX...need correct order for spark plug wire connections to distributor?????
I accidentally disconnected the spark plug wires going to my distributor, and now I have no idea which one of the 4 wires goes where...If anyone out there has a 94 civic I would greatly appreciate your help. I would do trial and error but I am not sure if this would cause some serious damage to the car.
The best way to give me the info is to look at the distributor as a clock with cables connected at 3, 6, 9 & 12 o' clock. So you can just tell me which "time" is connected to which spark plug number( numbered 1-4 from left to right)
For example, you could say 3 o'clock on the distributor is connected to spark plug #2.
Any help or advise would be greatly appreciated.
James,
Old Aug 17, 2004 | 06:41 PM
RedlinedVTEC's Avatar
Default Re: 94 Civic DX...need correct order for spark plug wire connections to distributor????? (cnh4)
1-3-4-2 starting at the bottom left pole and going clock-wise.
Old Aug 17, 2004 | 07:03 PM
jefe's Avatar
Default Re: 94 Civic DX...need correct order for spark plug wire connections to distributor????? (RedlinedVT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">1-3-4-2 starting at the bottom left pole and going clock-wise.</TD></TR></TABLE>
He means starting at top left pole.
Facing the distributor, 1 is top left. 2 is bottom left. 3 is top right. 4 is bottom right.
Old Aug 17, 2004 | 07:05 PM
jefe's Avatar
but i guess in your clock example:
12 is plug 1
3 is plug 3
6 is plug 4
9 is plug 2
Old Aug 20, 2004 | 06:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jefe &raquo;</TD></TR><TR><TD CLASS="quote">
Facing the distributor, 1 is top left. 2 is bottom left. 3 is top right. 4 is bottom right.</TD></TR></TABLE>
No I don't.
3 4
1 2
is what it would look like if you were looking right at the distributor. Your order is correct, but 90 degrees off at the distributor.
urtz
Nov 29, 2006 07:28 PM
irdprelude
Feb 19, 2005 12:51 PM
Quick Silver
Nov 23, 2002 11:39 AM
