Car wont start after replace dist rotor...and spark plugs
i replace the igition rotor (bosch) and my (NGK) spark plugs and my car wont start.... it cranks.....my wires set up is 13
42
1994 integra ls b18b
Thanks
42
Thanks
Did you install the parts yourself? Make sure the spark plugs are gapped to correct specs. Some spark plugs aren't always set at the factory. Maybe something went wrong with the distributor while installing the new rotor. Check the distributor and the cap.
check to make sure the 2nd and 3rd wire are in the correct spot. one is slightly longer than the other. i had these 2 mixed up and my car wouldnt start either. the length of those 2 wires matters. they are about one inch difference in length.
You know 1 is closest to the timing belt. Is that wire in the right spot? Did you set your firing order the right way? Our engines do turn counter clockwise. Make sure the rotor is screwed down. Also make sure you didn't throw it on backwards. I have seen some rotors where it is possible to set them 180 off(must be some sort of defect)
rotors should be keyed in. the plug wires dont matter the spot they're in on the distributor... as long as you have the correct order (1-3-4-2 go clockwise if looking at the distributor cap.)
other than that, check all the connections again.
still dont know what is the problem...i took off the distributor and let my friend take it to the shop and see what happen..
thanks for the info guys
micah13x
11
Apr 14, 2011 03:09 PM
bcumby
Dec 15, 2007 02:36 PM
