will a 88-89 integra ecu work with my stock si enigne
Old Aug 17, 2004 | 05:30 PM
4DRmafia's Avatar
Default will a 88-89 integra ecu work with my stock si enigne
if so then what type of integra ecu should i get? ls or what esle is best for my engine ?
Old Aug 17, 2004 | 05:35 PM
ek_99_SiR's Avatar
Default Re: will a 88-89 integra ecu work with my stock si enigne (SkipMic2006)
keep ur pm6.. but if u must insist get a 88-89 ls ecu
Old Aug 17, 2004 | 05:37 PM
4DRmafia's Avatar
can u tell me what the difference between them ?
Old Aug 17, 2004 | 05:46 PM
King-Kong's Avatar
ok the PR4 ecu (LS) will run your car pig rich and alot slower and bad as hell on gas, if you can grab a pg7 ecu from a 88-89 integra standard. higher fuel and spark curves and is made for a d16a1 or if you can grab ahold of a ZC ecu, same deals. the pg7 is made for a 1.6L while the PR4 is made for a 1.8, anything else you want to know im me and i will be gladly to help.
D-Boi901
Jan 9, 2007 08:33 PM
cooly22
May 12, 2004 07:30 AM
turbohf
Oct 14, 2003 06:41 AM
twitchm80
Oct 4, 2002 03:09 AM
