ENERGY SUSPENSION MOTOR MOUNT BUSHINGS
Old Aug 17, 2004 | 03:12 PM
vteckilla7's Avatar
Default ENERGY SUSPENSION MOTOR MOUNT BUSHINGS
OK, im thinking about ordering a set ,but it says for manual trannys only,unfortunatly I have an auto. I really only need the front bushing, just wondering if the mounts are the same and if they will work
Old Aug 17, 2004 | 03:40 PM
Daemione's Avatar
Default Re: ENERGY SUSPENSION MOTOR MOUNT BUSHINGS (vteckilla7)
The fronts are the same on both manual & auto. It's the rears you wouldn't be able to use.
Old Aug 17, 2004 | 03:50 PM
SuperSlow's Avatar
They come in pairs. Same front for auto. You won't need the rear anyway.
Old Aug 17, 2004 | 04:28 PM
Kal's Avatar
Kal
just watch out, your car will vibrate like crazy afterwards haha.
Old Aug 17, 2004 | 05:45 PM
vteckilla7's Avatar
Default Re: ENERGY SUSPENSION MOTOR MOUNT BUSHINGS (Kal)
well it cant be worse than my motor tilting front and back, i'll live with the vibration
Old Aug 17, 2004 | 06:42 PM
VSBB6's Avatar
I have a set of Place Racing front and rear mounts on my SS, they are very stiff and the car vibrates pretty bad at idle. However the good part is engine response has much improved, and launching the car is more immediate than before. Every gear shift is stronger as there is less engine movement, I highly recommend this mod if you dont mind to sacrifice a little comfort.
Dbach
Feb 3, 2009 11:48 AM
0618turbocivic
Suspension & Brakes
Oct 30, 2006 05:36 PM
davidcrx89
Apr 21, 2006 10:10 PM
dtrtw
May 31, 2005 05:07 PM
PH3593A
Oct 27, 2004 08:26 PM
